Polymer replacement for Wet cap
  • jayjr1105
    • 281
    I have a Gateway socket 478 board that looks like it was built like a tank (polymer caps and Rubycon MBZ all around the CPU) but it has a single Sanyo WG or WX cap near the 24 pin that is bloated. It's a 2200uf 10v. What's the lowest value I can go with a Polymer? I have a few Panasonic FM's at 1500uf. Is that too low? Otherwise I will have to order.
    I'll grab a picture when I get home.
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Polymer replacement for Wet cap
    I always like to go with the same uF value. The voltage could be higher but defo not lower.
    • jayjr1105
      • 281
      I've heard several times that if you go with solid polymer caps, you can go down in capacitance by a good bit.
      Ryzen 3600x
      FX-8802 Iron
      • LLLlllou
        • May 2011
        • 201
        If it's by the power connector, it's probably either the input cap for a VRM, or decoupling for the memory. FM 1500uf 10V is about halfway between WG and WX in both ESR and ripple rating, so would probably be OK.
        A 1500uf 6.3V polymer should be even better.
        Replacing wet electrolytics with polymers is not a black and white, one rule fits all, situation. In the output of CPU VRMs where ESR is king, it's quite common for engineers to specify HUGE capacitance solely because it's the only way to get sufficiently low ESR with a wet electrolytic. In this case, polymers with 50% or less capacitance can be substituted, as long as you don't go below the minimum required by the circuit. Unfortunately there's no way to know what that minimum is without doing a shitload of math. 50% is the generally excepted minimum that usually works, but not always. I usually try to stay with at least 8200uf
        • Stefan Payne
          • 1267
          Pls make a picture.
          I don't know what that Cap is for...
          • jayjr1105
            • 281
            Here's the CPU area, they all look good surprisingly
            Ryzen 3600x
            FX-8802 Iron
            • Perry Babin
              Lowest ESR capacitors, preferably liquid electrolytics but polymer also welcome
              by Perry Babin
              I'm looking for suggestions for electrolytics that are 10mm diameter and up to 25mm tall, through-hole radial capacitors with 5mm lead spacing. The value needs to be in the range of 330uF to 470uF. I typically use 35v caps due to their lower ESR vs 16v caps. Currently, the Panasonic FC is being used but the FM series is under consideration.
              This is for the primary side of a switching power supply in a car audio amplifier.
              Is there a way to calculate power dissipation in a capacitor to predict which will operate at a lower temperature? For example, a 470uF may have a...
              10-16-2025, 05:20 AM
            • EFritz20
              Xbox classic/original 10v 3300uf Polymer replacement?
              by EFritz20
              For polymodding an original Xbox i'm looking for polymer replacements of the following capacitor:
              2x 10v 3300uf Nichicon PW
              One is on the left side of the board, the other one on the right as you can see the picture i linked below (the two big brown caps).
              Could i just use 2200uf polymers to replace them or do i really need the capacitance?
              I have searched the forum already but could not find an answer for it.
              Thanks....
              03-25-2022, 04:47 AM
            • chth96
              Should I replace polymer capacitor?
              by chth96
              a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
              I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
              Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
              Is this ESR value of polymer capacitor correct?...
              11-18-2022, 04:22 AM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • the_rem
              Unknown transformer : how to find a good replacement part ?
              by the_rem
              Hello guys,
              I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
              I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
              04-23-2025, 01:48 AM
