I am in the process of replacing the caps on my motherboard. All of the caps read like 22uf 16v. Do I have v or vdc on my computer? Does this mean I should replace these caps with those showing 16v also. What about the 16vdc caps would those work. I'm confused about this voltage thing. Thanks in advance
Difference between 16v and 16vdc caps
Re: Difference between 16v and 16vdc caps
its dc
ac caps would read like more than 100v -
My friend has some caps to give me and all of his say 2200uf, 6.3v and 1000uf, 6.3v and 220uf, 16v . So all of them end in the voltage part with just a "v", like the caps on the motherboard right now. Can my friends caps be used provided the temp range, etc is the same?Comment
yes but you must check that the capacitors are low esr
the first thing to check is that they are 105oC and not 85oC
then you check the brand / series
if you tell me that i will tell youComment
no damage, just instability
what you can do is get the caps and then look at what is written on them and we can tell you if they are good or notComment
V = volts
DC = DC (direct current)
The "V" you see assumes DC.
In other words 16 v and 16 vdc are exactly the same thing.
.Mann-Made Global Warming.
- Dr Seuss
Originally posted by gwozdzI don't know about the low esr status of the capsMann-Made Global Warming.
- Dr Seuss
Originally posted by gwozdzLike would it damage something or just not last as long?
Anything from just being unstable to exploding parts or catching on fire is possible.
https://www.badcaps.net/forum/showthread.php?t=211Mann-Made Global Warming.
- Dr Seuss
Originally posted by willawakeyes but you must check that the capacitors are low esr
I just received this info on two of the caps he has. Both are 105deg
This is what is written on each cap:
Sanyo, S.E.24, WG, 1000uf, 6.3v
Rubycon, T0229, MBZ, 3300uf, 6.3v
Does this translate into low esr or notComment
This is Sanyo WG series.
Ripple 1140, ESR .030
This is Rubycon MBZ series.
Ripple 2800, ESR .012
Those are both premium brands and premium grade. [Very low ESR, high Ripple.]
- They rarely fail unless you have a bad power supply or a heat problem.
- Dr Seuss
Hey Guys, Thanks for all the help. When I get the caps, then the fun starts. I need to first read more from this wonderful web site and forum. This will be my first attempt to revive a motherboard. If a set of new caps doesn't work, in the trash it goes. That's about as far as I dare to go in repairing the thing. JohnComment
If yo have Sanyo and Rubycon going bad I'd be looking at the power supply as the problem.Mann-Made Global Warming.
- Dr Seuss
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
Howdy folks,
The GX260 strikes again, I just now noticed that a bunch of smaller caps on the motherboard are bad.
There's no indication of what series these are, but they have the same color wrap as the HM series. They're rated at 22uf and 25v and about 5mm x 6.5mm. The only other markings are the temperature rating (105 degrees Celsius) and what I assume is a date code - A236. The data sheet for the HM series doesn't include caps with these ratings. I've attached some images of the caps themselves and where they are/were on the motherboard.
Does anyone...-
- Loading...
