Panny FS series caps good for switching power supply?
    • Jul 2011
    • 6070
    Newmark has a sale of that series caps I think about buying some but I want to know if ESR value is to low .0013
    • 31291
    Re: Panny FS series caps good for switching power supply
    you didnt give any other info about the cap.
      • Jul 2011
      • 6070
      http://www.newark.com/webapp/wcs/sto...&storeId=10194
      • Stefan Payne
        • 1267
        Depends...
        What the original cap is, where you want to use it and so on.
          • Jul 2011
          • 6070
          I would like to use them on the output side of the power supply right there 2200uf on this 5 volt@5 amp power supply there 4 of them I was thinking of put 2900uf instead 2200uf
            03-31-2024, 02:12 PM
            07-01-2024, 06:34 AM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
            After all of...
            07-13-2024, 08:14 PM
