3.5 mm Lead Pitch
  • Neo2_000
    • Apr 2005
    • 180
    3.5 mm Lead Pitch
    Hi y'All,
    I work at computer shop so I have a good supply of Mobos to experiment with. I have got my technique down pretty well even though I am not using the most suitable soldering equipment. I built an ESR meter courtesy of Dick Smith Electronics here in Oz and have just been using old measured acceptable replacement caps to date.
    But now I am going to up the ante and purchase some new ones to repair some select boards which have real potential.
    This is where my problem started. Most boards apart from Intel use 1000uF x 6.3v junk electrolytics - OK enough, but the Wire Lead Spacing on the Caps is 3.5mm. Now try finding a cap to fit that bill! Took a while, but I finally tracked down a candidate, allbeit a rather expensive one.
    It is the Rubycon 10ZL1000M8X20, a 10v capacitor but the only suitable one I could find with a 3.5mm Lead Pitch. Thanks to the info in the FAQ on this forum which identifies the ZL series as a prime candidate I am now confident in my choice and at A$1.24ea, I could use some reassurance!
    If anyone knows of a cheaper alternative avaliable here in Oz, please let me know.
    Looks like I am hooked on this Badcap thing. I don't earn a huge amount and I obviously enjoy delving into the entrails of a Mobo, so this is a good way to score a potentially good board at a cheap price.
    I have come to love certain scenarios such as the A-Open AK73 - an AMD board packed full of Rubycons except for 2 only vulnerable junk caps
    I have observed that some manufacturers are now using quality caps in critical locations such as the CPU voltage supply area while still using junk caps on the rest!
    Probably 2 out of 3 badcap boards we see are Azzas and the worst offenders are the Chhsi caps although the Lelon brand while not often encountered may just be a contender for the crown!
    Thanks for the all the good info on this site - it is a real goldmine.
    Neo.
  • karatzdi
    Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
    by karatzdi
    I know some might say... just buy another one. Sell it as parts..!
    So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
    Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
    Spent some time downloading the Service...
    06-11-2024, 08:38 AM
  • Eh546
    Beginner, practicing to unsolder on a lead free xbox 360 board, it is hell.
    by Eh546
    Don't hesitate to tell me what i do wrong and if you have any tips and tricks, because i want to learn and improve.
    I have a 60w iron that can go up to 450c, cone tip, i usually set it at 400. I applied flux on solder, tinning the tip then applying new lead solder to the joint so that it can mix with the lead free and lower the melting point, then i tried to suck up the melted solder with the solder sucker. But that didn't work since the lead solder doesn't seems to mix with the lead free one. I also tried applying flux to a wick and the board, then tinning the tip of the iron and...
    05-24-2020, 06:59 PM
  • chj4591
    gddr5 ball lead?
    by chj4591
    gddr5 memory ball lead size?
    0.4mm 0.45mm 0.5mm​
    05-05-2025, 10:42 PM
  • RetroComputingGrotto
    Viewsonic VA2010wb (High Pitch Squeal At Power On)
    by RetroComputingGrotto
    I've got a monitor on my workbench at the moment that makes a high pitch squeal (that I cant hear as my ears are too old) when you power it on and lasts a couple of seconds before quitening and apparently it can be heard at regular intervals whilst on.
    On opening up the monitor and looking at the PCB the usual suspects showed their heads so I have already replaced all the electrolytic capacitors.
    The other issue that was reported with this monitor was the fact it took ages to start displaying anything after pressing the power button.
    What component(s)...
    02-03-2025, 06:00 AM
  • Stanley1843
    BEST 505 Vs Mechanic Brand Reballing Balls with Lead
    by Stanley1843
    has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.
    06-22-2024, 11:06 AM
