33uf in place of 22uf?
  • mikay786
    • Aug 2014
    • 765
    Need to replace 5 caps on subwoofer amp section but only have 3 x 22uf caps left.
    Can i use 33uf caps as a substitute?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: 33uf in place of 22uf?
    Impossible to say without any details about the circuit the caps are being used.
    • CapLeaker
      Leaking Member
      • 8179
      any pictures? and circle the cap(s) that you want to change.
      • mikay786
        • Aug 2014
        • 765
        This one here, all the orange caps are 22uf
          by momaka
          03-12-2025, 03:42 PM
        • tony359
          Best tool to place electrolytic SMD caps on a board
          by tony359
          HI all,
          I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
          When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
          The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because...
          01-28-2024, 06:23 AM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
