Help identifying SMT caps - GeForce 7900GT
  • Asuga
    • Nov 2008
    • 5
    First of all, here is the exact card in question, with the caps circled.
    http://www.isarapix.org/pix9/1227899373.jpg
    The information off the top of these SMT caps reads as follows :
    BP
    100
    ETZ
    Now the problem isn't so much that the caps are bad, but that the previous owner of this card did not check clearance in the board before pushing it in, and as a result both smt's were snapped off.
    I still have them (though theyre all but useless at this point) so i can confirm that the above code is correct.
    I've cleaned off the pads and removed the original legs that were soldered in place still, and it's basically ready for a new set of SMT's to be working fine again, problem is i can't seem to track down what exactly these SMT's are, i'd be greatful if someone here could shed some light on to the matter
    Even more useful would be if i could find out what the specs for them are, and located a suitable replacement on http://rswww.com
    Thanks in advance, i'll be back a few times a day to check up on the thread and answer any questions you might have about them that could help with identification.
  • kikkoman
    • Jul 2007
    • 691
    Re: Help identifying SMT caps - GeForce 7900GT
    these are Rubycon TZV series, 25V 100uF.
    from what i can tell by the silkscreen, through-hole components should work in both locations.
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      i dont think these caps are too significant to worry too much about specs. just use the lowest esr available to you
      i see on the photo provided they have made possibility for smt or thru hole caps in those positions. so you have option
      i think they are 100uf
      most importantly is the voltage which would be either 4v or 16v depending on whether they are on the input or output.
      BP
      100
      ETZ
      is not helpful to me for the voltage
      if you use 16v then no probs, if you use 4v or 6.3v etc and that is 12v input then they pop,
      really need a pic of a different card with different caps in those positions which may help identify the voltage
      once we find that this is easy fix
      edit : oops too slow, good find indeed kikkoman
      i think 25v over spec, likely to find max 12v on input
      • Asuga
        • Nov 2008
        • 5
        Amazing work guys, i totally appreciate it!
        Now knowing exactly what they are looking at it from a repaiting point of view, i think i'd be much more comfortable using the thru hole caps, not to sound lazy but could you maybe suggest some i could order from rswww.com (i'm from uk)
        As i'm not entirely familiar with the ESR side of things when using different type caps.
        Again, thanks a lot!
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          yeah i would probably go with the panasonic fm
          http://uk.rs-online.com/web/5261430.html if you want radial lead and not smt.
          those are 6mm
          personally i would replace with 470uf 16v just for the hell of it (a better cap but only experiment would tell if its of benefit to the circuit)
          http://uk.rs-online.com/web/5261389.html but that would be experimental. those are 8mm
          • Asuga
            • Nov 2008
            • 5
            those are 6mm
            Thanks, i'll give the radials a try, they should work fine, as for the experimentals i don't think it's really needed, the old caps were broken off my the previous owner, it's not really like the caps failed under normal conditions or anything.
            Will order tomorrow or money and let you guys know how it worked out.
            Thanks a lot for the advice.
            • fl0w
              GeForce 6800GT recap, need help identifying caps and finding replacements
              by fl0w
              I just noticed that my Asus V9999GT (GeForce 6800 GT) had some swelling capacitors. I managed to identify the brown ones, which are Nippon Chemi-Con KZG series, 6.3V 820µF, which I plan to replace with this.
              But for the yellow ones, I guess these are Fujitsu caps, without being able to identify which series... A picture of the video card is attached to the topic.
              I need to replace:
              • 2x 2.5V 1500µF => I plan to use this
              • 2x 16V 330µF=> I plan to use this
              • 1x 6.3V 680µF=> I plan to use this
              Am I correct with the cap choices?
              Thanks for...
              10-02-2024, 11:28 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
              NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
              The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
              10-02-2024, 08:52 AM
              by momaka
              03-12-2025, 03:42 PM
              NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
              The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
              10-02-2024, 07:51 AM
