Info on 820uf 8x20mm nichicon hn and 820uf 8x25 chemicon kzg
  • billse
    • Jan 2006
    • 15
    Hi, since trying to ask a question in a dead thread didn't seem to help, Anyone have specs on these two types of capacitors?
    1. 820uf Nichicon HN 8X20mm
    2. 820uf United-Chemicon KZG 8x25mm
    Question, Would replacing the above with the ones listed officially in the available datasheet be OK?
    Both of these appear on a intel D865GLC boards, different revisions. The Datasheets aren't really helpful, does not even list the above.
    Any info would be appreciated?
    Bill
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Info on 820uf 8x20mm nichicon hn and 820uf 8x25 chemicon kzg
    Pretty sure D865GLC is on Intel's list of boards that came with faulty HN and HM.
    If date codes are 2001-2004 they are (or probably will be) bad.
    Date code is [letter][2 digit year][2 digit week]
    KZG don't like heat. Would not purchase them as replacements.
    You neglected to mention the voltage rating.
    http://www.nichicon-us.com/english/index.html
    http://www.chemi-con.co.jp/cgi-bin/C...?allproducts=1
    Mann-Made Global Warming.
    - Dr Seuss
    • billse
      • Jan 2006
      • 15
      Oh, 6.3V.
      Sorry forgot to link to the other one where i asked too,
      https://www.badcaps.net/forum/showth...6501#post56501
      Bill
      • DrewPhillips
        Capacitor Diarrhea - Nichicon PL Series
        by DrewPhillips
        Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
        The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
        03-02-2025, 10:18 PM
      • nick3092
        Mid/late 80's Nichicon Yellow Caps
        by nick3092
        I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
        08-28-2022, 03:56 PM
      • chth96
        Is there datasheet for nichicon LXJ series?
        by chth96
        I want to calculate capacitor ESR referring to below guide.
        https://forum.digikey.com/t/calculat...-from-tan/2633
        I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
        I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
        Is there anyone who still has old nichicon datasheet which has information of LXJ series?
        11-20-2022, 08:11 AM
      • chth96
        Is there any datasheet for nichicon RT(M) series?
        by chth96
        A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
        https://www.badcaps.net/forum/troubl...e-been-blew-up
        and I finally fixed​ this retro game console by soldering varistor and glass fuse.
        But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
        I have spare console...
        11-28-2023, 03:36 AM
      • spiros.p
        EV dsp,replace the nippons lxz with nichicon fw ?
        by spiros.p
        Hi guys.I have two EV dsp processors and before two years i do full recap to both. The units have before recup thousands hours running.On output input coupling caps (16 pieces) i solder nippon lxz series 100mf 63v (this time i don't have other stock) i know is low esr caps.Last week have found and order nichicon fw standard audio series.Is a good reason to replace the nippons lxz with nichicon fw ? The units get better sound? Or get worse?Thanks for any advice.
        12-19-2023, 12:26 AM
