Shopping list
  • cpt.charlie
    • Sep 2013
    • 270
    • Spain
    Shopping list
    Hi, i need to keep some commonly used caps in stock for my home repairs (ATX PSU, some monitors and TV) since getting low ESR caps locally can be quite challenging i wanted to place an order to RS-on line (the only company that charges reasonable shipping prices in Spain). Should i add/remove any cap?other series to consider? Suggestions?
    May boss gave me some caps he got from aliexpress (nippon chemicon, nichicon) but you know, likely fakes, i'll upload some photos
    25 x Panasonic EEUFR1H220, 22μF, ±20%, 50 V dc, Serie FR Radial
    10 x Panasonic EEUFR1H101, 100uF, ±20%, 50 V dc, Serie FR Radial
    25 x Panasonic EEUFR1H100, 10uF, ±20%, 50 V, Serie FR Radial
    25 x Panasonic EEUFR1H470, 47uF, ±20%, 50 V, Serie FR Radial
    5 x Panasonic EEUFC1H330, 33uF, ±20%, 50 V dc, 600mO, Serie FC Radial
    10 x Panasonic EEUFR1E102L, 1.000uF, ±20%, 25 V dc, Serie FR Radial
    5 x Panasonic EEUFR1E152, 1500uF, ±20%, 25 V dc, Serie FR Radial
    5 x Panasonic EEUFR1E222S, 2200uF, ±20%, 25 V dc, Serie FR Radial
    10 x Panasonic EEUFR1E471L, 470uF, ±20%, 25 V dc, Serie FR Radial
    10 x Panasonic EEUFR1E561L, 560uF, ±20%, 25 V dc, Serie FR Radial
    10 x Panasonic EEUFR1E681, 680uF, ±20%, 25 V dc, Serie FR Radial
    10 x Panasonic EEUFR1C102, 1.000uF, ±20%, 16 V dc, Serie FR Radial
    10 x Panasonic EEUFR1C222, 2200uF, ±20%, 16 V dc, Serie FR Radial
    5 x Panasonic EEUFM1C332L, 3300uF, ±20%, 16 V dc, Serie FM Radial
  • Behemot
    • 4845
    • CZ
    Re: Shopping list
    Yes, suggestion. Check my stock. Besides stocking exactly caps for ATX, display&TV power supplies, UPS, motherboards&VGAs, you will get it for fraction of the price of those big-ass corporations including shipping costs.
    • BigPete
      Panasonic Heatpump Dryer Repair
      by BigPete
      I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
      The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
      In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
      Unfortunately the whole machine has to come apart to fix it.
      I have...
      11-01-2025, 06:40 PM
    • AndreStarTrek
      Cant find the old or new model of the Panasonic CE Z Serie
      by AndreStarTrek
      I want to replace the caps of my Sega Dreamcast power supply. But one of them is a 400v 47 CE Z. Some how I cant find that serie or the replacement for that serie.
      I am not sure if they really are Panasonic. They are all CE with FC and NHG and that are Panasonic models. But all caps are branded with M.
      Anyone can tell me what serie or replacement serie this is?
      11-07-2020, 09:03 AM
    • Andre Gilbert
      by Andre Gilbert
      11-20-2024, 08:52 PM
    • AquaMan Ua
      Problem with PANASONIC CF53 laptop after changing BIOS settings
      by AquaMan Ua
      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
      05-17-2025, 09:40 AM
    • Eh546
      Polk PSW125 capacitors choices for a beginner.
      by Eh546
      I was looking to repair my Polk PSW125 subwoofer plate amplifier, i've checked around the web and it seems to be a capacitors problem.
      Took apart the amp, and made a visual inspection, everything's seems fine, fuse ect no burn marks, but i noticed 3 caps that were a little bit bulged. One 400v 150uf, one 50v 47uf, and two 63v 47uf.
      I noted each caps voltages and uf anyways, and made a list on digikey. Some recommended Nichicon and Panasonics ones (FR and FM) serie. So I tried to stay with the Panasonics FM-A serie.
      I would like to know if the caps i selected...
      12-21-2023, 07:28 PM
