Looking for Bi-Polar 1.8uF 250Volt & 1uF 100Volt
  • UHU
    • Sep 2016
    • 35
    Looking for Bi-Polar 1.8uF 250Volt & 1uF 100Volt also Bi-Polar.
    Who makes / sells these values of capacitor?
    More details and photographs at: -
    https://www.badcaps.net/forum/showth...424#post721424
    Can buy internationally.
  • petehall347
    • Jan 2015
    • 4438
    Re: Looking for Bi-Polar 1.8uF 250Volt & 1uF 100Volt
    https://uk.rs-online.com/web/p/polye...itors/8076799/
    • UHU
      • Sep 2016
      • 35
      Interesting - that link is for a "Panasonic 1.8μF Polyester Capacitor (PET) 630 V dc ±10% series ECQE" (Panasonic P/N ECQ-E6185KF)
      In terms of performance is it a good idea to change capacitor chemistry from electrolytic to Polyester/Solid?
      Am thinking about the implications of this
      http://analogrules.com/capacitors.html
      I now realise the 1.8uF Capacitor is the ring capacitor for the telephones.
      Moving away from Bi-Polar electolytics could be quite an improvement - is there a thread comparing the effects of different capacitor chemistries at the same capacitance values?
      • UHU
        • Sep 2016
        • 35
        Kudos and thank you to petehall347 - your suggestion was just what was needed - fantastic results - see https://www.badcaps.net/forum/showth...424#post721424
        petehall347 - would you be able to decipher the remaining capacitor codes (like “F152Je., 400MEF1”) or point me in the right direction - are you a Transistor expert? If so please comment on the linked thread.
        • tony359
          Bipolar capacitor for vintage Apple CRT monitor
          by tony359
          Good day all,
          I have a question about some old monochrome Apple monitors.
          Inside those monitors there is one bipolar capacitor. From the schematics I have it's part of the horizontal linearity circuit.
          A friend replaced a bipolar 4.7uF 25V capacitor with a Nichicon bipolar 4.7uF 25V. The cap popped after about one hour. The new capacitor was much smaller than the original one but that's not a surprise as the original one was from 1980. (I am not sure whether the original was was actually 4uF and was replaced with a 4.7uF?)
          The new capacitor:...
          08-12-2024, 03:27 AM
        • Amminadabz
          What to replace an unobtainable bipolar elctrolytic?
          by Amminadabz
          Howdy folks, its been a minute.
          I'm working on a capacitor kit for my Korg C-15 digital piano, and it has a couple bipolar electrolytics (C27 and C34) on the analog board for which I can only find one direct replacement, but it's sold in multiples of 50.
          I've got a couple work-arounds in mind (Ebay NOS, testing with the og part, swapping for a ceramic), but what part can I recommend that will be reliably obtainable in the future? Would a ceramic or MLCC (not entirely sure what the practical difference is) be a good general replacement for bipolar electrolytics? It's...
          03-26-2023, 04:12 PM
        • Adenitz
          Replace electrolytic cap with bipolar one
          by Adenitz
          can I use this cap:
          https://www.tme.eu/en/details/ues1h4...tors/nichicon/
          Capacitor: electrolytic; bipolar; THT; 47uF; 50V
          to replace this capacitor: Electrolytic Radial E 47uF/50V 6.3x11 RM2.5 105°C Jamicon
          What exactly I can expect to install bipolar electrolytic cap instead a regular one?
          Thanks.
          02-02-2022, 07:44 AM
        • sigmeyer
          LG TV Need help replacing a Bipolar Small signal Transistor
          by sigmeyer
          Ok , so i got this TV from a friend of mine.So to start it off Its a plasma TV.When turned on it the red light comes on , then after a couple seconds the light goes off, and it repeats like that. You can hear the Relay click on for a few seconds then off ... So it wasnt an obvious short on the mains input thats for sure. I opened it up , and mind you, i have never seen an inside of a plasma TV so it suprised me to say the least. There are 3 massive power boards. The main one , then we have the board that is connected to another board which then goes to the TV (i assume those are some kind of drivers...
          10-16-2020, 03:28 PM
        • Cap_search
          Question about bipolar electrolytics
          by Cap_search
          Good morning all,
          Is it true that all the bipolar electrolytics are made/manufacturered of two "back-to-back" polar electrolytics in the - + + - configuration, and that would explain why they are usually larger than equivalent value of a common polarized electrolytic? (e.g. Muse UES)
          N.B.: polarized Silmic II are also usually larger than common electrolytic, though.
          07-22-2019, 02:45 AM
