2008 MacPro Memory Card Bad Cap
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    I have a 2008 MacPro (3,1), and out of nowhere, it shut down. The memory card was smoking from one of the inductors on the card. With the computer turned off, but plugged in, when I insert the memory card (which has 4 DIMMS on it), I hear a clicking noise (just once) and the inductor starts to smoke. Again, this is while the computer is turned off but plugged in.
    Upon further investigation, I found a blown cap, and the two next to it were swollen. Also, it looks like maybe an adjacent FET might also be damaged. Here are some photos - you be the judge.
    I'm not sure what kinda caps these are, nor am I convinced that simply replacing them will fix my problem.
    Any feedback would be much appreciated.
    Mike
    sigpic
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: 2008 MacPro Memory Card Bad Cap
    blue sanyo used to get called capistors ..and still do .. although those ones were from earlier times ..maybe the badness didn't get resolved ..
    test those capacitors for short circuit .
      • 31040
      those are OSCON series polymer capacitors.
      • EasyGoing1
        Shock Therapist
        • Sep 2016
        • 977
        Some of them simply couldn't hold their bladder and let loose all over the circuit board .... I dont think testing those would be necessary...
        sigpic
        • Drack
          Yup it's me
          • Nov 2016
          • 297
          • Venezuela
          Well a bad cap can make the fet (and inductor) extremely hot
          • UHU
            • Sep 2016
            • 35
            First step would be to change all the capacitors on the motherboard I would use Panasonic SEPC range for what is shown in your photos - your photo shows makings that should mean 270uF 16Volt.
            Panasonic SEPC of today is a newer generation than the Sanyo OS-Cons in your photo - Panasonic IIRC bought the OS-Con division of Sanyo and refined the chemistry involved - have recapped various motherboards (a couple were 10 years old) that had the original mix of electrolytics, Fujitsu polymers and Panasonic SEPC's all on the one board - testing some of the removed polymers showed the SEPC's were still fine while the Fujitsu polymers were shot - it is also notable that the SEPC's cost more so the motherboard manufacturers seem to use them sparingly (to solve problem circuit designs) vs the Fujitsu polymers.
            Didn't think your Os-Con's were still on sale for 2008 production runs - maybe Apple had old stock of Os-Con's
            Either way I replace ALL the motherboard capacitors and things have always come back to life for me.
            Yes the capacitor could make a fet or anything else it is connected to extremely hot because the capacitor could for instance go (effectively) short circuit and become a current draw which will heat up the devices supplying the cap with its excess current.
            Once you have done that try it or change the smoking component(s?) and fet's then try it out.
            • Mint Waxed
              • Aug 2016
              • 35
              A unit from 2008 has reached the end of it's life so I would replace all electrolytic caps that are accessible.
              • EasyGoing1
                Shock Therapist
                • Sep 2016
                • 977
                These caps are on the MEMORY card which is separate from the motherboard ... are you suggesting that I replace every cap in the entire computer or just the ones on the memory card that went bad?
                sigpic
                  • 31040
                  just do the memory card for now.
                  the oscon's do go out of spec with age though, i have a load of them i recovered from p3 server boards - half of them were out of spec.
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    What do you mean when you say they have gone "out of spec"?
                    sigpic
                      • 31040
                      i mean on the tester the esr had gone up a bit or more common, the uf's had dropped a lot!
                      none had shorted,leaked or bulged though.
                      • EasyGoing1
                        Shock Therapist
                        • Sep 2016
                        • 977
                        Oh I see ... that makes sense ... so in other words, they were wearing out, and were no longer performing to their stated specifications even though they had not yet completely failed.
                        sigpic
                          • 31040
                          exactly, they would not have done any direct damage.
                            Alcor AU6368 USB 2.0 Flash Memory Card Reader Datasheet
                            The AU6368 is an integrated single chip memory card reader controller specially designed for notebook, hand-held and other PC peripheral devices, which require fewer components for small PCB area. It supports a widely used flash memory card such as CF, MD, SMC, xD Picture Card, MS, MS Pro, MS Duo, SD and MMC. It can be used as removable storage disks in enormous data exchange applications between PC and PC or PC and various consumer electronic appliances.
                            The AU6368 reads digital content saved on memory card that user captured with the portable device such as notebook, digital camera,...
                            10-23-2024, 03:26 AM
                            Lenovo ThinkPad X1 Extreme Notebook X Specification for Upgrade or Repair
                            This specification for the Lenovo ThinkPad X1 Extreme Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Extreme boardview and X1 Extreme schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                            09-06-2024, 07:20 AM
                            09-06-2024, 07:11 AM
                            DELL Precision 5530 Mobile workstation 5000 Specification for Upgrade or Repair
                            This specification for the DELL Precision 5530 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5530 boardview and 5530 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Precision...
                            09-06-2024, 07:14 AM
