Capacitor value
  • wkman
    • Oct 2008
    Capacitor value
    Can someone tell me the value of this capacitor? Not sure what 33J means.
    Thanks guys
  • kikkoman
    • Jul 2007
    • 691
    Re: Capacitor value
    I'd say this means 330nF.
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      Re: Capacitor value
      .33 uf
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Re: Capacitor value
        330nF = .33uF
        Only 2 digit markings are in pF, so .33pF
        The J = +/-5%
        Mann-Made Global Warming.
        - Dr Seuss
        • arneson
          • Sep 2005
          • 1267
          Re: Capacitor value
          Did you slip in a decimal point? It's large enough to be 300pf.
          Jim
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Re: Capacitor value
            Good catch.
            I'm not sure if the dot in front of the 33 is a decimal point or not.
            - Dr Seuss
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Re: Capacitor value
              But with cameras and zoom how do you know how big it is?
              - Dr Seuss
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                Re: Capacitor value
                it is a .33
                • MORETTIGIAN
                  by MORETTIGIAN
                  Title:
                  Description:
                  Procedure performed:
                  - Removed backplate
                  - Reapplied thermal compound
                  - Reassembled card
                  09-18-2025, 12:14 PM
                • Prolog
                  by Prolog
                  12-01-2024, 08:27 PM
                • chth96
                  by chth96
                  12-22-2023, 04:34 AM
                • chth96
                  Is it no harm to replace with capacitor without ripple current rating?
                  by chth96
                  When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                  Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                  But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                  Rubycon YK DataSheet (b...
                  04-19-2024, 05:19 AM
                • chth96
                  Should I replace polymer capacitor?
                  by chth96
                  a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                  I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                  Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                  Is this ESR value of polymer capacitor correct?...
                  11-18-2022, 04:22 AM
