Capacitor replacement problem
  • DannyBoy21
    • England
    I am fixing a power supply for a fruit machine, After removing the PSU and unscrewing the holding screws to reveal a capacitor rolling around freely with some burn damage under where it had been originally it occurred that I could indeed need a new one, specifically a 400wv 330uf 105°c Samwha snap in capacitor.
    After ordering a like for like replacement (not samwha) it arrived today, I was ready to whip the iron out and get to work then noticed, it has an extra terminal on the negative side, and obviously won't fit in a pcb with two holes.
    If I were to get the snips out and cut off this extra terminal it would fit perfectly and would look exactly the same as the other side. But this is electricity after all so I approach with caution. It also crossed my mind I could drill a small whole in the PCB to accommodate this extra terminal but it wouldn't have much to hold to if soldered I don't think.
    After many searches on google etc. I can find nothing regarding this extra terminal (as soon as you write in capacitor negative terminal you're inundated with polarity videos, links ect)Exact capacitor can be found on Amazon by searching 'BHC 330uf capacitor' and part number ALC40F1009DF.
    I have brought up the data sheet which also has no mention of said extra terminal, nor on the actual item listing (you can see it in the picture, slightly...if you know what your looking for)
    So my question after that long life-story is has anyone else come across these caps, and would it make a world of difference snipping off the extra leg as it is a second negative? Any information regarding this type of 1 pos 2 beg terminal would be handy.....
    Many Thanks and apologies about the long question..
    • 31170
    Re: Capacitor replacement problem
    i have done this before, the extra leg is just for extra strength holding it to the board.
    • DannyBoy21
      • England
      Ahh ok thanks for the reply
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Yes what stj said.
        Sometimes it's also a leg completely by itself, usually on larger caps.
        But same reason: for mechanical support of the capacitor.
        • DannyBoy21
          • England
          Thanks for the reply Per
          • MORETTIGIAN
            by MORETTIGIAN
            Title:
            Description:
            Procedure performed:
            - Removed backplate
            - Reapplied thermal compound
            - Reassembled card
            09-18-2025, 12:14 PM
          • artvandalai
            Where can I get compatible capacitor for replacement?
            by artvandalai
            Blew the capacitor on my analytical balance scale using the wrong power adapter. I need help finding a replacement compatible capacitor to buy. Will any 100uf 40v capacitor work as a replacement?
            12-28-2024, 10:15 AM
          • r2digital
            klipsch kda-500 amplifier suitable power supply capacitor replacement ?
            by r2digital
            I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
            04-18-2024, 03:50 PM
          • rwkish
            Discontinued Capacitor looking for Replacement
            by rwkish
            Capacitor has been discontinued (EGXF101ELL331MM20S) all of the replacements I have found have are smaller than 0.709" Dia (18.00mm). I would like to use the same size or at least close to the same size Capacitor. 19mm would be too big as they would touch and not be able to through hole mount. Tia...
            08-18-2024, 06:54 PM
          • Hylax
            Replacement capacitor options please?
            by Hylax
            Hi, I'm super new to this capacitor stuff but I've some basic soldering experience with old cellphones PCBs and headphones. I have this APAQ AR5K 820∆μF 3V Dc Capacitor from a motherboard that I'm looking to replace, photos I've attached. But I'm unable to find a 3V one like I've marked in the spec sheet in red (This is the one currently present in the motherboard). But the 6.3V one I can find (marked in blue) is of similar dimensions but different specs as mentioned in the table. Is it okay to replace it with higher voltage cap, slightly higher ESR, slightly lower ripple current, and double...
            08-09-2024, 11:25 PM
