Gigabyte GA-8ID533 went pop!
  • chrunchyhobo
    • Nov 2016
    • 17
    • U.K.
    hello,
    I just wanted to ask if anyone has had any experience with this motherboard (gigabyte GA-8ID533) and if anyone has had dodgy caps on it.
    I recently purchased a brand new (open box, anti static bag still sealed) GA-8ID533 mobo and one of the caps vented about 5 seconds after it posted.
    The mobo did not shut itself off, and DID post again (used a different PSU) after the venting (which I probably shouldn't have done).
    The cap in question is a Nichicon 1000uF 6.3v 8mm x 13mm cap located below the 5th PCI slot (hopefully shown in the picture if it uploads right) with "EC57" printed on the PCB next to it.
    From what I have read, I understand that Nichicons are high quality caps, so this has me confused a little bit.
    My questions are:
    1. Does anyone know what this cap is for?
    2. What could have caused it?
    3. Could it have been caused by the PSU I used? PSU was a CWT PUFP305P.
    Any info I have missed, please let me know.
    • 31288
    Re: Gigabyte GA-8ID533 went pop!
    what else is writen on the cap?
    i see "HN" ??
    • chrunchyhobo
      • Nov 2016
      • 17
      • U.K.
      i see "HN" ??
      It's HM(M).
      Also says A0301.
      Cant believe I missed those.
      • rhomanski
        nowhere man
        • 5157
        • U S of A
        Badcaps or goodcaps doesn't mean you can point to one and say, "It will never fail". It means you can point to one and say, "It probably won't fail". Ever been left standing on the side of the highway by a new car? Stuff happens.
        sigpicThe Sky Is Falling
        • chrunchyhobo
          • Nov 2016
          • 17
          • U.K.
          I know that, its just a bit more unexpected when a "good" brand fails.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8711
            Maybe Gigabyte put the wrong capacitor there and really needed a higher voltage one...
            Then again this should have been caught during initial testing...
            • Wester547
              • Nov 2011
              • 1268
              • USA.
              That's a Socket 478 board. A0301 means it was manufactured during the 1st week of 2003 (January) in Asahi, Japan. Nichicon had a large, bad batch of ultra low impedance capacitors (HM and HN series) from 2001-2005. They make good caps otherwise. I'm not surprised they would fail upon POST, after all those years of sitting in a sealed bag. It sounds like the electrolyte had attacked the aluminum oxide layer as it continually thinned in storage (when the electrolyte broke down, it could not repair the oxide film), so when bias was finally applied to the plates, BANG! Even the circuit voltage proved too much for those defective caps. That particular cap appears to be on the output of a linear regulator but tracing the underside may reveal otherwise. (M) is the capacitance tolerance (-+20%), not part of the series name.
              • ChaosLegionnaire
                HC Overclocker
                • Jul 2012
                • 3266
                • Singapore
                yes what he said. this is why i avoid gigabyte boards during the p4 and athlon xp and 64 eras. i saw a lot of gigabyte boards from that time period use nichicon hms. if u get one of those, it usually means a time consuming full recap of the board due to the faulty batch in the 2001-2005 time period when p4s and athlon xp/64s were being made.
                suitable replacements for your recapping exercise would be rubycon mbz, sanyo wg and panasonic fj.
                • chrunchyhobo
                  • Nov 2016
                  • 17
                  • U.K.
                  Thank you VERY much for that incredibly detailed reply, that has taught me quite a bit.
                  Got a pic of the underside in case that helps (top side pic for reference):
                  I presume that the chances of this being caused by my CWT featherweight PSU are slim?
                  And I bet you knew this question was coming: what should I replace it with and would it be a good idea to replace all the caps of the same type (total of 6)?
                  I know that I need a 1000uf 6.3v, would something like a Panasonic FC series or a Nichicon FW be suitable?
                  All the ebay listings for them say "for audio" or some such nonsense, I presume this is just a marketing term to get more hits?
                  And I suppose I should ask about the other caps on the mobo, which are 4x Rubycon MBZ 1500uF 6.3v T0245, 2x Rubycon MBZ 3300uF 6.3v T0242, 3x Rubycon MBZ 1500uF 16v T0241, 4x CHOYO MR 22uF 16v 11YJ and 6x TEAPO SS A3 100uF 10v.
                  Any of those out of a bad batch?
                  • chrunchyhobo
                    • Nov 2016
                    • 17
                    • U.K.
                    so a full re-cap is recommended?
                    the board also has TEAPO and CHOYO caps (specs in above post).
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      That's an awesome board! Little caps are cheap, so I usually replace them if they're from terrible brands, like the ones you listed....Some might say leave low microfarad caps alone, but I have seen a lot of them fail. Definitely not as critical as the VRM, buck regulator caps but they're already old caps from bad brands, and they won't be getting any better over time.
                      • chrunchyhobo
                        • Nov 2016
                        • 17
                        • U.K.
                        I think I am just going to replace them all just to be safe.
                        Looks like I might have to do the same with my Gigabyte GA-8IPE1000 Pro-G that I am going to be using in one of my many projects too.
                        should probably look at the caps on the ASUS P2B that I have in my '98 gaming pc too.
                          • 31288
                          DONT USE EBAY.
                          use RS for free delivery.
                          http://uk.rs-online.com/web/p/alumin...itors/7083548/
                          • chrunchyhobo
                            • Nov 2016
                            • 17
                            • U.K.
                            DONT USE EBAY.
                            I am poking around their site already, its just trying to choose what to get.
                            picking the right one is hard when you have absolutely ZERO experience in capacitors.
                              • 31288
                              that's why i put a specific link
                              the best thing is to use datasheets and then search for the part numbers at RS.
                              dont use FR around the cpu btw - they arent really good enough - you need poly's there.
                              • chrunchyhobo
                                • Nov 2016
                                • 17
                                • U.K.
                                too tall.
                                to replace the Nichis I need 12.5-13mm height and 8mm diameter.
                                http://uk.rs-online.com/web/p/alumin...itors/7497123/
                                these are what I found so far.
                                • Wester547
                                  • Nov 2011
                                  • 1268
                                  • USA.
                                  You could probably get away with leaving the Rubycon MBZ. They are good capacitors. Although given that they are 14 years old at this point, replacement may work in your favor.
                                    • 31288
                                    YXJ arent good enough.
                                    http://uk.rs-online.com/web/p/alumin...itors/7660040/
                                    MBZ would have to be replaced by poly's - nobody makes electrolytics wih spec that high anymore.
                                    • ChaosLegionnaire
                                      HC Overclocker
                                      • Jul 2012
                                      • 3266
                                      • Singapore
                                      get rid of those too. teapo may be barely acceptable for psus but they are garbage in mobos. choyo is just plain junk... nuff said.
                                      since ultra-low esr caps are hard to find these days, personally, i think u can get away with leaving the rubycon mbzs alone. i have an abit ic7-g max 2 with a boardful of rubycon caps. the cpu vrm output has 2004 datecode mbzs and they are still good as im typing this msg from it.
                                      • chrunchyhobo
                                        • Nov 2016
                                        • 17
                                        • U.K.
                                        I am NOT questioning your advice here, but what makes the Panasonic ones better?
                                        I would like to know what to look out for in the future.
                                        • DynaxSC
                                          GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                                          by DynaxSC
                                          I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                                          General test conditions:
                                          - Tested with Core i5 6500 and Core I7 6700K - no difference
                                          - Default BIOS settings, but tried also altering several memory setting - does not change anything
                                          What is wrong:
                                          With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                                          When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                                          03-21-2025, 06:23 PM
                                          Thermal pad thickness for various laptop GPU / Graphics Cards
                                          ASUS Dual RTX 2070 OC 8GB
                                          ASUS ROG STRIX RTX 3080 OC
                                          ASUS ROG STRIX RTX 3090
                                          ASUS TUF Gaming RTX 3080 OC Edition
                                          ASUS TUF GTX 1660 S-O6G GAMING
                                          EVGA RTX 3060 Ti XC GAMING 8GB
                                          EVGA RTX 3060 XC GAMING 12GB GDDR6
                                          EVGA RTX 3080 FTW3 ULTRA GAMING
                                          EVGA RTX 3080 TI FTW3 ULTRA GAMING
                                          EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                                          Gainward RTX 2080 Phoenix GS Specs
                                          Gainward RTX 3070 Phoenix 8GB
                                          Gainward RTX 3080 Ti Phoenix
                                          GIGABYTE AORUS RTX 3080 MASTER 10G
                                          02-09-2024, 08:08 AM
                                          A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                                          by momaka
                                          More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                                          And a shot of the label:...
                                          01-26-2022, 03:26 AM
                                        • nikovmiroslav
                                          Gigabyte A5 X1 Need Bios
                                          by nikovmiroslav
                                          Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
                                          Gigabyte A5 X1
                                          From motherboard:
                                          S/N: 1TNH55ER1350895
                                          P/N: 6-77-NH55ERQY-D02-2CGB
                                          On sticker from the back of the laptop:
                                          S/N: SN21351J000657...
                                          08-24-2025, 09:15 AM
                                          Gigabyte AERO 16 XE5-73UK948HP Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 16 XE5-73UK948HP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 XE5-73UK948HP boardview and 16 XE5-73UK948HP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 07:19 AM
