22uF / 400V ESR value ?
  • bianchi77
    • Jun 2016
    • 1121
    Everyone,
    I got ESR 1.1 Ohm for 22uF /400V electrolytic capacitor,
    Is it bad ?
    Cheers
    • 31293
    Re: 22uF / 400V ESR value ?
    make & series would help.
    • bianchi77
      • Jun 2016
      • 1121
      It's written Ltec and 105 degree....
      • diif
        • Feb 2014
        • 6978
        • England
        Have you searched for any of the data sheets for any of the Ltec caps ?
        The first three results are all Ltec data sheets.
          • 31293
          look for a 2 or 3 letter code.
          http://www.paullinebarger.net/DS/Ltec/
          • bianchi77
            • Jun 2016
            • 1121
            It's TY....from datasheet...I can not see ESR value ?
              • 31293
              they arent listed as low impedance, so it's common that the value is not given.
              how is the capacitance?
              • bianchi77
                • Jun 2016
                • 1121
                it was 26 uF and when I measure with analog metre....it stopped on 10K on 10K scale...can not be completely discharge...
                  • 31293
                  it may be o.k.
                  but if it's over the rated level it would be good to see the leakage level because sometimes a cap goes leaky and the uF rises at the same time.
                  • bianchi77
                    • Jun 2016
                    • 1121
                    it may be o.k.
                    How can I know the leakage level ? from analog meter ? Does it say a leakage on it and needs to be replaced ?
                      • 31293
                      you cant, only some digital component testers give you that data.
                      • bianchi77
                        • Jun 2016
                        • 1121
                        I'd better replace it then...
                          • 31293
                          that is simplest.
                          • cap__
                            Can I replace 15uf capacitor with 22uf?
                            by cap__
                            "If I wanted to replace an old 15uF/400V capacitor with a new one,
                            I have a new 15uF/400V and a new 22uF/400V capacitor. When measured, the new 15uF reads only 13uF, and the 22uF reads only 20uF. Can I use the 22uF capacitor?"
                            11-29-2023, 11:16 AM
                          • Adenitz
                            Replace electrolytic cap with bipolar one
                            by Adenitz
                            can I use this cap:
                            https://www.tme.eu/en/details/ues1h4...tors/nichicon/
                            Capacitor: electrolytic; bipolar; THT; 47uF; 50V
                            to replace this capacitor: Electrolytic Radial E 47uF/50V 6.3x11 RM2.5 105°C Jamicon
                            What exactly I can expect to install bipolar electrolytic cap instead a regular one?
                            Thanks.
                            02-02-2022, 07:44 AM
                          • madscientist750
                            Replacing electrolytic caps by solid caps on old motherboards
                            by madscientist750
                            I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                            I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                            I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                            10-19-2025, 06:10 AM
                          • Perry Babin
                            Electrolytic cap endurance
                            by Perry Babin
                            From what I've found, the endurance of a liquid electrolytic cap is determined by the loss of electrolyte. If a cap is rated for 1000 hours. That's typically for a straight run test. How would the life vary if the cap is intermittently heated to its rated temperature (105C). Maybe for an hour at a time then cooled back to 30-40C (just a random number). Would the life still be 1000 hours?
                            Does it make a difference in the life expectancy if the cap is heating from ripple current (internal heating) instead of from the external ambient temperature?
                            Why do polymer capacitors...
                            10-18-2025, 05:21 PM
                          • Perry Babin
                            How do organic polymer caps compare to liquid electrolytic for reliability
                            by Perry Babin
                            I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
                            If not organic polymer, what would be the caps that could take the most abuse?
                            08-18-2025, 04:04 PM
