Drilling with a pin
  • Bishop
    • Apr 2009
    • 99
    Drilling with a pin
    I just recapped six PC based DVR cards. A total of thirty-six caps of different sizes.
    I was wondering if anyone else drills with a needle when replacing a bad cap.
    If the left over solder is hard to draw out, try inserting a pin into a dremel like rotary tool and drill out a hole through the solder. It's not really drilling, the spinning needle heats up the solder and melts it. It create the perfect size opening and with a little left over solder it seals the cap in place with very little effort.
    It may be an old practice, but it came to me about 5 years ago and I used it today. 36 caps in 90 minutes is not bad.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Drilling with a pin
    never drill a multi-layer PCB, its a recipe for disaster.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      Drilling? no. Using a pin to clear the holes yes, I usually do it when the solder can still be liquefy with the iron but can't be removed with copper braid or a bulb based vacuum de-soldering iron.
      I just heat up the hole and run the pin through then remove the iron as I slowly withdraw the pin, allowing the solder to attach to the pin as it comes back out. Sometimes that not possible and you have to clean the pin from the other side while iron is still applied before removal of pin. It might require to be little bit ambidextrous but once that's done you have a hole for a cap.
      • Bishop
        • Apr 2009
        • 99
        Use the pin only to clear a path for a cap through the left over solder in the two ports
        Works great
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3266
          • Singapore
          lol... hope this is a lesson learned not to use the term "drill" so loosely! "drill" implies a large tool was used to cut/make a hole that did not exist before. i suggest using the term clearing or vacating the holes. if anyone has a better verb to suggest we use, please feel free to post and let us know.
          • Bishop
            • Apr 2009
            • 99
            I called it drilling because years ago I used a cordless drill with a sewing needle to clear a path in the left over solder. It was big and bulky but the idea seemed logical.
            Since then I use a Dremel with a small hat pin, the same size as the needle. Light weight and easier to use than a drill.
            Today, I replaced two bad caps in a PC power supply and I "cleared" a path in all 4 holes with the pin and the dremel.
            As the pin spins it gets hot enough to melt solder and matches the hole to the cap pins size. Surprisingly, the spinning pin melts the solder easily and without much pressure. You don't need the speed of a dremel. Even at slow speeds it will heat the solder to make a hole. It works very well for me and I thought it might help others.
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              It's called friction drilling.
              Can also be used instead of welding to join steel together:
              https://www.youtube.com/watch?v=5JbnDXw-0pM
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                QFT!
                i can show you a machine shop owner who will agree.
                an irreplaceable board where his idiot maintenance man drilled out a 4 layer board.
                did it to 5 ics.
                i loved the billable hours to fix that.
                pushing a stainless needle through molten solder is the way if you dont have a vacuum station like i do.
                • jiroy
                  • Jun 2016
                  • 2416
                  • Lebanon
                  Originally posted by kc8adu
                  QFT!
                  did it to 5 ics.
                  Well said . A Needle and patience is more than enough . better than damaging multi layers . When things go much tougher , Sometimes i mix a quick heating with a sudden swift knock ..
