Foxconn 865PE7MF-SH caps
  • emy12
    • Aug 2011
    • 34
    I have this motherboards, I want to replace one of the caps beside the CPU, there are three on two sides of it. 680uf 4v. I do not have these, instead i have some 820uf 6.3v, the same size.
    Thank you.
    PC Cooler Master Centurion CAC-T01-EK/Q9550s/GA-EP45-DS4/GEIL Black Dragon 4GB/MSI 7790 OC/ 2.5 500 7200HDD/AX760W/Win 10 Pro
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    Re: Foxconn 865PE7MF-SH caps
    u need to tell us what size and series are those or just post photos of the caps with the labelling clear on the photos. caps by the cpu have to be of the ultra low esr type or they will not work.
    • emy12
      • Aug 2011
      • 34
      Thank you for reply.
      I have attached two photos showing clearly the caps. In fact just one among those small once is a bit swollen. The once i have are 820uf 6.3v Rubycon, the size is the same.
      I had other one swollen, between PCI slot, i changed it, i had a few of them 1000uf 6.3v.
        • 31017
        you should use polymers to replace those MFZ, anything taller could hit the heatsink - and it's a hot area anyway.
        • emy12
          • Aug 2011
          • 34
          Yes, you 're right, those are a bit taller, the heatsink will not fit.
          I have a few polymers around, are these good?
            • 31017
            nichicon LE series 6.3v is fine.
            • emy12
              • Aug 2011
              • 34
              So, do i have to replace only the bad one? I could replace all three on that side. I have only four of them for now.
                • 31017
                personally i would replace all of them, but if you only have 4 then replace the ones that look bad.
                that row of 3, both outer ones look bad - the tops should be perfectly flat.
                • emy12
                  • Aug 2011
                  • 34
                  I will do once i will get a soldering iron. I had one but it broke yesterday. The soldering gun is useless. I ordered one from Amazon, a soldering iron.
                  https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
                  • ChaosLegionnaire
                    HC Overclocker
                    • Jul 2012
                    • 3264
                    • Singapore
                    yes that 60w iron will do just nicely for computer mobos.
                    and i see u have some ost caps near the cpu vrm. those have to go as well because ost is infamous for failing without any signs of bloating etc. u dont want to be scratching your head wondering why the board failed without any signs!!!
                    • emy12
                      • Aug 2011
                      • 34
                      Yes, there are lots of them, ost, I know they have bad reputation, the good thing is that i have replacement for them all. I ll see now, if the soldering iron works fine i will replace them.
                      • emy12
                        • Aug 2011
                        • 34
                        The job is done, replaced three of them with polymer, tested and working fine.
                        The problem is the polymer caps are a bit higher than the original once and the heatsink sits on them, there is any problem?
                          • 31017
                          yes, if the heatsink actually touches them then it's not going to be pressing against the cpu!
                          • ChaosLegionnaire
                            HC Overclocker
                            • Jul 2012
                            • 3264
                            • Singapore
                            are u using the stock intel heatsink? it may also cook the caps due to conducted heat from the heatsink, making u having to the change the caps *again* a few years down the road. this is especially apparent if u use a prescott cpu. what cpu is it anyway? if its a p4 prescott 3.4ghz or faster or any pentium d cpu, i recommend u get a third party heatpipe cpu cooler to replace the stock cooler instead.
                            • emy12
                              • Aug 2011
                              • 34
                              It is just flat the top of the CPU with the top of the caps.
                              It is a Pentium 4 531 CPU, it has a stock intel heatsink. Apparently never been cleaned since new. I will look for different heatsink. I do not want to invest much in it.
                              • ChaosLegionnaire
                                HC Overclocker
                                • Jul 2012
                                • 3264
                                • Singapore
                                OMG!! that heatsink is so dusty, the dust bunnies look like either a giant beard and moustache or really think and bushy pubic hair. thank you for giving me nightmares!!
                                  • 31017
                                  yea, that needs to go in the sink - and the fan!
                                    by momaka
                                    03-12-2025, 03:42 PM
                                  • eryjus
                                    by eryjus
                                    05-10-2023, 11:21 AM
                                  • Paxman_Swede
                                    by Paxman_Swede
                                    Hello!
                                    01-14-2025, 09:51 AM
                                  • captain150
                                    by captain150
                                    03-16-2025, 07:34 PM
                                  • Foetuss
                                    Gigabyte GA-6OXT :: caps question
                                    by Foetuss
                                    Good evening
                                    I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                    Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                    But I was also suprised about the bigger boys, which are 330µF 25V.
                                    Could it be they used 25V caps because they were cheaper / available at that time?...
                                    02-11-2025, 12:22 PM
