Replacing Caps--and a short story
  • stretch0069
    Screwed Up Super Moderator
    • Oct 2003
    • 2662
    • oooo ess aaaaaaaaa
    Well...I was bored at work the other day so I went digging around to see what lost treasures were to be found. I managed to find a drawer full of Pace soldering accessories and supplies. I thought to myself "wow...I wonder if there is actually a good Pace kit around here?" There is a Pace MBT station, but it has been seriously neglected. I'm in the process of rehabing it. Anyway, I do a bit more poking around and find an old Pace PPS-200C just like the ones we had in the Corps. It was awesome. I was almost (dare I say???) giddy. I blew out the dust, turned her on, and all was well. Just had to replace the tip for the extractor. Took the VP6 in Friday to replace the caps. It took me less than 30 minutes to prepare the new caps, pull the bad caps, put in the new caps.
    I couldn't believe how easy it was getting the solder out of the holes. Piss on that solder-pult POS. It was awesome. They want to throw it out. I know where is going if it comes to that. :
    To make a long story short, if you have the right equipment, its incredibly easy to replace the caps, and any other component for that matter. The only thing I haven't tackled is BGA and from what I understand, you have to have a very expensive piece of equipment for that. I've done soldering under a microscope before. Nerve wracking, but interesting.
    As a side note, I've been trying to find the AC cord for the station that powers the Resis-tweez, Conduc-tweez, and Strip-tweez accessories. THe Pace P/N is 7000-0005. Anybody have an idea??
    Anyway, if you're having problems with your caps, give me a hollar. I actually like soldering.
    "Its all about the boom....."
    Guns kill people like spoons made Rosie O'Donnell fat.
    We now return you to your regularly scheduled drinking.
    "Fear accompanies the possibility of death.....calm shepherds its certainty"
    Originally posted by Topcat
    AWD is just training wheels for RWD.
  • rmaich
    • Apr 2005
    Pps-200c
    Regarding your use of the PPS-200C. I've a pile of older equipment I need to rebuild (with hundreds of old caps to replace), so I purchased a PPS-200C on eBay the other day (it just arrived yesterday), and I spent about 3 hours last night cleaning it up, removing old property stickers, tape, etc., installing new rubber feet, replacing rusted screws, etc. so it's looking fairly good, and it fired up fine. I'm not familiar with all of the features on this unit, however, and hope you might be willing to give a few pointers and some explanations based on your experience.
    • DynaxSC
      Extreme High Current & Low Voltage Short Killer ??
      by DynaxSC
      Hi Folks
      I'm looking for a extreme high current short killer solution for a reasonable cost.
      I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
      After taking off the socket, the shorts dissappear again.
      The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
      10-15-2024, 10:13 AM
    • Stephen
      MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
      by Stephen
      I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
      02-06-2025, 12:03 PM
    • adelfr2009
      HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
      by adelfr2009
      I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
      After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
      09-28-2025, 10:21 PM
    • Victor Moreira Silva
      Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
      by Victor Moreira Silva
      I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
      Well, my decice specs are the following:
      Model: Acer Nitro 5 AN517-54-55T5
      CPU: Intel Core i5-11400H
      GPU: NVIDIA GeForce GTX 1650
      Motherboard: GH51G LA-L181P Rev:1c
      The symptom:
      When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
      05-26-2025, 10:49 AM
    • aaronkatrini
      Help me find the short circuit on this WORKING Nvidia GTX1650
      by aaronkatrini
      Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
      Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
      04-18-2024, 03:15 PM
