I have a Gigabyte GA-8SIML s478 motherboard and a Fortron FSP Source 250W ATX PSU ready for recapping. All I now need are the new caps. Old caps:
Gigabyte mobo:
- 4x GSC [LE] 3300uF 6.3V
- 4x GSC [RE] 1500uF 16V
- 7x Choyo [XR] 330uF 25V
All four GSC LE series caps were bulged. RE series showed no visible signs of failure, but GSC is GSC so i decided to remove them anyway. Same goes for the Choyo caps, they didn't show any signs of failure... But due to their bad reputation i also removed them. And even though they are only 330uF some of them were placed next to DIMM slots so for the sake of reliability i'll replace them. They do have a vent stamped onto them. Mobo was working when pulled out.
Fortron PSU:
- 3x Teapo [SEK] 3300uF 10V
- 1x Fuhjyyu [TMR] 2200uF 16V
- 1x Jamicon [TK] 470uF 25V
- 1x Jamicon [TM] 1000uF 10V
Also there is a large resistor which had brown, transparent goo in it's base (probably heated up glue) which had DE-SOLDERED ITSELF and was held on by the glue... The resistor cannot be identified because the covering was burnt off O_o this can't be good. The solder side of the PCB is also darkened from that part.
The PSU was working when it was pulled out. And yes, it's a genuine FSP.
So, i need some suggestions for caps to use. And if anyone can find info on the FSP PSU, i'm all ears.
EDIT: Should I also replace the primary caps? They are Teapo LXK 470uF 200V.
Gigabyte mobo:
Fortron PSU:
