flashing red lpght and clicking ln46a550p3fxzc
  • v.i-guy
    • Jun 2016
    • canada
    hi everyone I posted this in another on going thread but I thought I would start a new post about my problem. I have the same problem as most guys do that have a 46 Samsung. I got this tv off of a guy for free he said it wouldn't turn on will when I got it home it turned on and worked for a couple of months but once in awhile the right side of the screen would go kinda black brown shady .if I moved the screen or tapped the tv it would go back to a good pic again. will I went to turn it on two days ago and the dreaded flashing red light and clicking. so I pulled the power supply and found that someone had replaced the capacitors but they were not soldered very will they were cold soldered so I resoldered them and put it back in and made a mistake I crossed the two plugins at the bottom of the board cn1808 cn1809. I still don't know I how I could have done that but the tv still came on for about 5 minutes and the picture was great but then it shut down again and back to the dreaded flashing and clicking. so did I fry something else by getting them backwards any help with would be great.
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Re: flashing red lpght and clicking ln46a550p3fxzc
    Have you tried unplugging and swapping cn108 and cn109 to where they are in the correct position?
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
    • R_J
      • Jun 2012
      • 9624
      Swaping the cn1808 cn1809 won't make any difference, they are just for the backlights
      I would check for bad solder connections on all components attached to the heatsinks
