PNY 6800GS unknown caps
  • trodas
    • Jan 2006
    • 770
    • Czech republic
    I recently look on my PNY 6800GS graphic card, because after I saw recent polymer-only recap made by Big Pope (sort of like polymer orgy, lol) I get the idea that perhaps now are possible to get higher / better capacity polymer caps of the required diameter. The card use all SMD caps and it go like:
    PNY 6800GS
    3x 1200uF 4V d10 (Sanyo Os-con SVP)
    5x 180uF 16V d8 (Sanyo Os-con SVP)
    4x 100uF ???V d6.3 (???)
    The nice polymers are easy, but what are these 100uF (likely 100uF) caps? For what voltage they are? On the top of them, they are looking just like these caps: http://img47.*************/my.php?image=snapinel9.jpg
    Silver case, black text.
    What is written on them is:
    BE
    100
    ETZ
    ...and another two ones, still d6.3 bit different height goes by like this:
    BF
    100
    CTZ
    Anyone have any idea what they are?
    "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
    "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
  • brispuss
    • Dec 2012
    • 54
    • NZ
    Re: PNY 6800GS unknown caps
    For future reference, these unknown capacitors are, I believe, Rubycon TZV series.
    The BE capacitor is rated at 25 V, and the BF capacitor is rated at 16 v. Both are 100 uF.
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
    • Foetuss
      Gigabyte GA-6OXT :: caps question
      by Foetuss
      Good evening
      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
      But I was also suprised about the bigger boys, which are 330µF 25V.
      Could it be they used 25V caps because they were cheaper / available at that time?...
      02-11-2025, 12:22 PM
    • Bartoloni
      testing voltage of unknown SMD caps
      by Bartoloni
      usually i have to replace motherboard caps (0805 SMD) ...
      the most used (and usually shorted) is the 4.7 uF 25V (HP boards)
      i have a lot of donnor boards... and i take some caps (same size) i measure the capacity using 2 different multimeters (when CAPS are removed from board)
      when i found a 4.4 or 4.5 uF caps i place 19V at the sides and i watch if they blow...(or maybe just start absorbing some milliAmperes)
      i was sopposing that if the caps are not blowing the voltage can be 25 (or in some rare cases 50V) and i use them as a replacement for the bad...
      06-23-2021, 11:34 AM
