PNY 6800GS unknown caps
  • trodas
    • Jan 2006
    • 770
    • Czech republic
    I recently look on my PNY 6800GS graphic card, because after I saw recent polymer-only recap made by Big Pope (sort of like polymer orgy, lol) I get the idea that perhaps now are possible to get higher / better capacity polymer caps of the required diameter. The card use all SMD caps and it go like:
    PNY 6800GS
    3x 1200uF 4V d10 (Sanyo Os-con SVP)
    5x 180uF 16V d8 (Sanyo Os-con SVP)
    4x 100uF ???V d6.3 (???)
    The nice polymers are easy, but what are these 100uF (likely 100uF) caps? For what voltage they are? On the top of them, they are looking just like these caps: http://img47.*************/my.php?image=snapinel9.jpg
    Silver case, black text.
    What is written on them is:
    BE
    100
    ETZ
    ...and another two ones, still d6.3 bit different height goes by like this:
    BF
    100
    CTZ
    Anyone have any idea what they are?
    "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
    "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
  • brispuss
    • Dec 2012
    • 54
    • NZ
    Re: PNY 6800GS unknown caps
    For future reference, these unknown capacitors are, I believe, Rubycon TZV series.
    The BE capacitor is rated at 25 V, and the BF capacitor is rated at 16 v. Both are 100 uF.
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
    • Foetuss
      Gigabyte GA-6OXT :: caps question
      by Foetuss
      Good evening
      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
      But I was also suprised about the bigger boys, which are 330µF 25V.
      Could it be they used 25V caps because they were cheaper / available at that time?...
      02-11-2025, 12:22 PM
    • madscientist750
      Replacing electrolytic caps by solid caps on old motherboards
      by madscientist750
      I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
      I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
      I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
      10-19-2025, 06:10 AM
