Servo Drive Issues - Not many Caps
  • bdoss@calysta.com
    • Apr 2016
    • 8
    Having trouble with an API Controls brushless servo drive; drive does not properly control motor, rather, motor just stutters and hums rather than rotating smoothly. Have positively tested the motors against working drives. There look to be only a few caps and some other diodey type things. The tall cylindrical caps are not bulging but might be a little less than perpendicular to the plane of the PCB. No juices or sauce exploding from any of the caps either. Anything look funky to you professionals out there? Many thanks in advance.
  • R_J
    • 9594
    Re: Servo Drive Issues - Not many Caps
    My first guess would be the block (igbt ipm) attached to the heat sync, I can't see the number but it is most likely a bunch of fets and drivers that control the output to the motor. I have not worked on any that small but the ones I repair us a 7mbp150ra-060 which are for larger motors. look up that parts pdf and you should be able to check if the output fets are shorted
    • floppydisk
      • Apr 2016
      How would you check if the Fets/transistors are shorted or bad? Below is the schematic and also a link to the datasheet.
      Here's the datasheet:
      Even if we do find that it is shorted, it looks like finding that part is not easy. Any suggestions on that? I found one on Ebay in germany (I think).
      Thanks,
      Mark
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        So this is a 3 phase motor. Have you made sure the diode are not blown on one of the phases?
        • bdoss@calysta.com
          • Apr 2016
          • 8
          I have not checked diode integrity. I am a newb. Can you advise on that procedure?
          • floppydisk
            • Apr 2016
            @keeny123. Just to be clear, we want to make sure the diodes are all working between:
            K --> R, S, & T
            R, S & T --> A
            U, V, & W --> E or N
            P1 --> EU, EV, and EW
            I would take a continuity test on a multi-meter and check to see if I have continuity?
            Thanks - Mark
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              There are some decent videos on Youtube on how to test an IGBT.
              Try to search Google for example: IGBT testing with multimeter
              • bdoss@calysta.com
                • Apr 2016
                • 8
                K --> R, S, & T
                R, S & T --> A
                Thanks - Mark
                I tested the leads mentioned in both diode-test mode and resistance/continuity with my DMM. The component is still on the PCB, PCB is not powered, shorted gates to emitters prior to testing. Here's what I got:
                Diode Mode:
                K --> R (0.552V/"OL"), S (0.552V/"OL"), & T (0.552V/"OL")
                R (0.552V/"OL"), S (0.552V/"OL") & T (0.552V/"OL") --> A
                U (0.429V/"OL"), V (0.428V/"OL"), & W (0.429V/"OL") --> E or N (E=N)
                P1 --> EU (0.429V/"OL"), EV (0.429V/"OL"), and EW (0.429V/"OL")
                Resistance Mode:
                K --> R, S, & T (3.042 Ohm, all same)
                R, S & T --> A (decaying signal, 35 Ohm and dropping)
                U, V, & W --> E or N (1.812 Ohm, E=N)
                P1 --> EU, EV, and EW (1.812 Ohm)
                Is this component still working?
                • R_J
                  • 9594
                  Going by the diode tests it seems to be o.k. Usually a transistor or diode will short and when checked would show a dead short.
                  Do you get any faults showing on the status display?
                  • bdoss@calysta.com
                    • Apr 2016
                    • 8
                    The drive display shows "d" when powered up with setpoint of zero, and "E" with any non-zero setpoint. It's a single character display.
                    According to the manual, "d" is "bus voltage not present." "E" is "Enabled, bus voltage present."
                      by momaka
                      03-12-2025, 03:42 PM
                    • SluggerB
                      Can't find exact matching caps for replacements, what should I get to prevent video issues?
                      by SluggerB
                      I have an old Tivo. The Power Supplies are known to have caps that fail. Here are the caps that come with the original power supply:
                      I could not find replacement caps with the exact same specs. I followed an online guide and recapped the power supply with caps with these specs
                      The power supply now works, however the HDMI video is giving me eye strain. I don't know how a capacitor on a Power supply could impact an HDMI video signal, but it does, the Tivo interface has a flicker now and the color/brightness is off. So I want to get some new caps...
                      04-05-2024, 07:47 PM
                    • eryjus
                      by eryjus
                      05-10-2023, 11:21 AM
                    • Paxman_Swede
                      by Paxman_Swede
                      Hello!
                      01-14-2025, 09:51 AM
                    • captain150
                      by captain150
                      03-16-2025, 07:34 PM
