Technics SU-8011 Receiver - Looking to recap it
  • Vinster
    • Feb 2016
    • 25
    Hi Guys.
    I just got this receiver for $30. the function switch was buggered up but I think I have that sorted out. (Testing shortly)
    I've read that recapping this unit does it justice and I'm wondering which caps I should be looking at using for the replacements. There is a local electronics store around the corner but the stuff that's there is cheap Chinese stuff... in a pinch it works. But I don't really want to go that route on this restoration.
    This amp was assembled in 1979.
    I'm not looking to use the best of the best considering on what I paid and overall what this is worth ($75-$100). But I am out of touch on what brands are the cheap, average and what the high end units are.
    Here is a link to the specs if you are wondering; http://www.hifiengine.com/manual_lib.../su-8011.shtml
    Looking forward to your recommendations.
    Vin
    EDIT: I've tabulated a caps list.
    Value - Voltage - Quantity
    6800uf - 42v - 2
    220uf - 50v - 1
    47uf - 35v - 2
    100uf - 50v - 1
    100uf - 35v - 2
    220uf - 35v - 1
    220uf - 25v - 1
    47uf - 6.3v - 6
    3.3uf - 50v - 2
    100uf - 6.3v - 2
    47uf - 50v - 2
    3.3uf - 50v - 2
    24 in total.
  • rhomanski
    nowhere man
    • 5157
    • U S of A
    Re: Technics SU-8011 Receiver - Looking to recp it
    As a general rule of thumb for vintage gear, use low impedance for most, low leakage for sky blue or yellow or orange. I use Nichicon from Mouser. They have the best assortment, very few times am I forced to substitute. The KL series is low leakage or low noise, the PW series is low impedance. For bi-polar, I use EP series because they are 105 degree. With the KL series you can usually find them in 10% tolerance instead of 20%. The good news is capacitors have improved so much over the years a general purpose is just about as quiet as a low noise from back then and half as big.
    sigpicThe Sky Is Falling
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      Amazingly clean and in order you should have fun.
      • Vinster
        • Feb 2016
        • 25
        I don't see a KL series on their website, just KZ, KT and KA. Do you have a link?
        This is what I see their offering is. http://ca.mouser.com/new/nichicon/Nichicon-Audio-Caps/
        Vin
        • Vinster
          • Feb 2016
          • 25
          Thanks, this will my first of a few amp's to re-cap. this one being the easiest. I am looking forward to it.
          Vin
          • rhomanski
            nowhere man
            • 5157
            • U S of A
            Re: Technics SU-8011 Receiver - Looking to recap it
            Here you go, http://ca.mouser.com/Nichicon/Passiv...z0zlbmZ1z0yp6m . They are under regular capacitors not audio grade. I have some very expensive equipment and I can assure you audio grade capacitors are pretty much a scam. In the audio path what matters is leakage which causes hiss. Another thing to look at if you have a nice amp is the transistors and diodes. Semiconductors are much quieter than they were in the seventies. If you find a 726 transistor or a 1313, replace it on principle as well as any with the black plague, you know black legs, that's corrosion and an invitation to shorts between legs up at the plastic under the transistor.
            • Vinster
              • Feb 2016
              • 25
              here are a few questions, I know the voltage on a cap is what it's rated for. But in an audio circuit. bumping up to the next available voltage cause any changes to the circuit?
              1)
              One cap thats in there is a 47uf @ 6.3v, on mouser they only start at 10v. I know that electrically isn't an issue. but again, what about an audio circuit?
              2)
              and any recommendations on power caps?
              Vin
                • 31288
                the power caps are 10mm pin-pitch snap-in type.
                rubycon has a good range of those - but they co$t.
                the 47uf will be fine at 10v or 16v / 35v (if it's cheaper)
                • rhomanski
                  nowhere man
                  • 5157
                  • U S of A
                  Bumping it up to 10v will make no difference. Just keep an eye out for bi-polars. I usually make a drawing of each board showing each component and polarity in reference to each other so I don't make a mistake. Get a cheap meter with Hfe if you change transistors because sometimes you'll get some with the same number but the legs will be swapped. Instead of ECB the new ones will be EBC. It can get more confusing if your substituting transistors.
                  For the large power filters I have always used Panasonic T HA series but they recently started discontinuing the ones I used.
                  This will work I think. Measure the originals and see if it's too big around. http://ca.mouser.com/ProductDetail/N...qbmxvr0mMJ4%3d .I'll tell you one thing, if you lose that double transistor in picture 4 you'll have a time finding a replacement. I bought the last Pioneer had a few years ago I got a few more from little diode but that was the last as far as I could find. A sub can be made but it's more trouble.
                  • rhomanski
                    nowhere man
                    • 5157
                    • U S of A
                    Sorry STJ, posted at the same time. Didn't mean to step on your toes.
                    • Vinster
                      • Feb 2016
                      • 25
                      I didn't realize that they were snap-in type. I was thinking of getting these
                      http://ca.mouser.com/ProductDetail/N...aX95u8F7QVc%3d
                      but the ones you recommend has a lower leakage current and 3x the life.
                      it's worth the extra buck.
                      Vin
                      • CDNBrewer
                        Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                        by CDNBrewer
                        Hello Everyone,
                        I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                        Symptoms:
                        • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                        • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                        • I swapped the Left and Right surround
                        08-05-2025, 09:29 PM
                      • wolf1976
                        wireless receiver for 6 speeds fan control with remote control
                        by wolf1976
                        hi i have a receiver that is destroyed from the overvoltage i guess
                        my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                        the motor fan has not label
                        i have an other receiver operational
                        In your opinion can i measure the voltage at the output ?
                        what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                        thanks in advance...
                        07-23-2025, 03:12 PM
                      • directdrive
                        Query - Technics SP10 Mk2 direct drive TT recap
                        by directdrive
                        I have recently acquired a Technics SP10 Mk2 direct drive turntable from 1981.
                        It came from a radio station so I presume it has spent most of it's life in an air-conditioned studio.
                        It has a quartz lock system with a number of circuits including a quartz oscillator, frequency generator and phase control ciruits.These are based on (74xx) ICs and it has (x16) (74xx) IC's and (x95) transistors on 3 boards.
                        Recently I was attempting to connect some oscilloscope probes to check the control circuit as per the manual and slipped and shorted...
                        01-10-2021, 05:56 PM
                      • CdDvdFlash
                        DSE GE6878 possible TV receiver dying remote not working well
                        by CdDvdFlash
                        For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
                        07-03-2024, 03:55 AM
                      • sanalelevenstar
                        Yamaha RX-V485 receiver. After encountering a "version error"
                        by sanalelevenstar
                        I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
                        After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
                        I managed to find the service...
                        09-10-2025, 01:54 AM
