Help identifying a Varistor
  • phunny
    • Feb 2016
    • 5
    I've learned a lot about varistors but still haven't came across any that match this guy.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Help identifying a Varistor
    Wow, made in Canada board.
    Type 07 k20 varistor into your search engine and the first result is
    which leads to Epcos S07K20.
    --- begin sig file ---
    --- end sig file ---
    • phunny
      • Feb 2016
      • 5
      Saved me, thank you.
      • chth96
        How can I identify varistor which have been blew up?
        by chth96
        I mistakely pluged 100v japanese retro game console to 220v outlet.
        So It seems that glass fuse and varistor have been blew up.
        I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
        Is there any way to identify varistor type in my sega saturn PSU?
        Any reply would be appreciated.
        EDIT:
        It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
        11-26-2023, 08:52 AM
      • AustinCER
        Need Help Identifying this LCD FPC for Dell G3 15 3590 Gaming Laptop
        by AustinCER
        I am in search for some help in identifying the LCD FPC. It is a connector for a plug-able eDP cable.
        Attached is a photo of the FPC.
        Model: Dell G3 15 3590 Gaming Laptop
        ST: 79QYJT2
        Thank you very much in advanced....
        11-03-2025, 02:55 PM
      • nicktasios
        Macintosh Quadra 840AV PSU
        by nicktasios
        I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
        12-22-2024, 05:07 AM
      • RetroComputingGrotto
        Need Help Identifying A Diode
        by RetroComputingGrotto
        I have an MSI 3PA1 monitor on my bench that wont power on. I have tested the 2 (what I believe to be Schottky Diodes) and both are shorted in both directions (a common faulty from what I can see on Google) but I'm not certain what the markings on the Diodes mean so I need some help in identifying which ones to order from Mouser please?
        I've done a search for 101C 5100C and all I can find are datasheets for 5100C which say they are 20-100V 5A Schottky Diodes but I'm not 100% sure if this is correct or not and what significance the 101C is.
        We...
        09-22-2025, 06:47 AM
      • Khoja
        Lenovo Ideapad Flex 5 14IAU7 (LC57-IAU MB 213062-1M) identifying elements
        by Khoja
        Hello friends, I have a Lenovo Ideapad Flex 5 14IAU7 laptop that doesn’t turn on. When I opened it, I found a burnt resistor on the motherboard. Since I couldn’t find a schematic for this model, I need help identifying the parameters of this resistor.
        • Model: Lenovo Ideapad Flex 5 14IAU7
        • SN: PW0AZK3W
        • Motherboard: LC57-IAU MB 213062-1M 448.0RH09.001M
        Any assistance would be greatly appreciated!...
        09-19-2025, 09:56 AM
