HP MicroStar MS-6577
  • BlakeW
    • Apr 2008
    • 13
    Well, i've got a stock motherboard in an (almost) stock HP tower. I wasn't expecting very good quality, what with it being OEM. However, i found quite a few rubycon caps in it (right near the cpu), some pannys (mostly low uF), as well as (*vomits*) a few teapos (low to mid-high uF). :S
    Is this any cause for concern?
  • ant3202
    • Jun 2006
    • 274
    • Singapore
    Re: HP MicroStar MS-6577
    wat kind of problems had u faced?
    so far i knw rubycon in VRM is fine, panny is fine too.
    i think teapo caps are for sound card , etc..
    • BlakeW
      • Apr 2008
      • 13
      i haven't actually had any real problems with the board as yet, just wanted to know if any of it is questionable
      • weirdlookinguy
        • Sep 2007
        • 1638
        I have an MSI MS-6526 in my system (Pavilion 753n). Mine has all Nippon KZG's and Teapos... but the Teapos seem to be holding up fine after 4 years of daily use. All KZG for VRM.
        • BlakeW
          • Apr 2008
          • 13
          I was wondering what brand the KZG's were, thanks for indirectly telling me :P mine has them also.
          • ant3202
            • Jun 2006
            • 274
            • Singapore
            KZG (Capacitor Series For Mainboard) - Nippon Chemicon
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              unless your fans fail the kzg will be fine.
              they dont seem to last in hot machines.
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • AkaBukai
                Is it okay to flash stock bios onto the motherboard's BIOS?
                by AkaBukai
                Hi there,
                I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
                The little LED on the power button is flashing slowly and nothing happen.
                This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
                So I decided to flash the BIOS using a cheap programmer.
                And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
                I also...
                12-19-2024, 12:15 PM
              • ignacio.ino27
                (BIOS) Asus X541UVK Rev 2.0. Stock ME REGION
                by ignacio.ino27
                I share with us this binnary file that i have edited the ME Region (from original dump version to stock 11.6.0.1126).
                It is "stock" region and working.
                BIOS: X541UAK.306
                MOTHERBOAD: X541UVK Rev. 2.0
                CPU: Intel Core i3 7100U Kaby-Lake R
                ║ Family │ CSE ME ║
                06-08-2021, 05:39 PM
              • roman_v61
                Samsung Book2 pro np950xed-kf1US motherboard stock issue
                by roman_v61
                this is my kinda final resort.
                My sister was very happy with her samsung laptop,
                she used it for 2 years.
                suddenly the laptop failed to start and after exmining it in the lab,
                it appers the motherboard is dead and I need to get a new one.
                the problem is that there is no motherboard to be found nowhere on the web.
                can somebody advice what can I do?
                except for buying a new laptop.
                laptop model:
                samsung book2 pro np950xed-kf1US
                thank you in advance,
                Roman
                07-14-2024, 09:27 AM
