Counterfeit UCC LXZ Parts in SE Europe
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    A manufacturing facility for my employer, located in SE Europe, recently bought "UCC LXZ" parts that turned out to be laughable fakes. The outer wrapper was black instead of blue, the vent scoring was a right-angle "X", there were multiple styles of rubber bung for a single "date code", none remotely similar to what UCC actually uses. The "105C" and date code were rotated 180 degrees. The thickness of the letters and numbers of the value/voltage was wrong. The catalog of crude errors was rather amusing.
    Some genius at my employer bought these fakes from a non-authorized distributor. When we contacted UCC in the Chicago area, they said that they had heard of the distributor, who had been caught before selling fake UCCs (fake KMMs, IIRC). They claimed in the first case that they were also victims of the fakery (Yeah! Right!)
    The "moral of the story," try to buy caps from sources you know get parts from the original manufacturer or get parts from an authorized distributor.
    PeteS in CA
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Counterfeit UCC LXZ Parts in SE Europe
    keeping us in business.
    do they really get destroyed or go out the back door.
    i was dealing with burnt cars for hyundai. a representative from head office personally watched each one crushed (to avoid parts going on the market)
    • Newbie2
      • Sep 2005
      • 885
      Any pics on these fake UCC LXZ parts?
      My gaming PC:
      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
      ASUS M4A77TD AMD 770 AM3 Motherboard
      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
      ASUS Xonar DG 5.1 Channel PCI sound card
      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
      Antec Three Hundred Mid-Tower Case
      Microsoft Windows 10 Pro 64-bit
      Microsoft Windows 7 Ultimate SP1 64-bit
      • Mark D
        Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
        by Mark D
        The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
        10-29-2024, 03:15 PM
      • 2elw
        SVOD4 PCB pictures + parts
        by 2elw
        Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
        STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
        GW1N-UV9UG169C6/I5 FPGA - Its a...
        07-04-2025, 12:23 PM
      • SurrealMustard
        What parts can be salvaged from a plasma with a damaged display panel?
        by SurrealMustard
        I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
        03-09-2025, 08:29 PM
      • DynaxSC
        Asus Rog Strix B360-I Gaming - Parts Identification
        by DynaxSC
        I have an Asus Rog Strix B360-I Gaming with missing parts. I know there is a resistor missing for sure, but nearby it seems there might have been also a transistor or mosfet. Below the picture of the area on the board with the missing parts. The interesting area is inside the rectangle.
        I'd appeciate if somebody could make a detailled picture of this area from a working board and post it here. Getting the parts values would also be helpful. The revision of the board is 1.02 .
        Thanks in advance...
        08-23-2023, 07:56 AM
      • AJ847.63e
        Australian repair parts suppliers hunt
        by AJ847.63e
        Hi All,
        Just wanted to reach out and see if anyone knew of any good stores in Australia for sourcing OEM repair parts from. In particular I'm needing a galaxy tab S7 plus screen, frame and battery and a Asus zenbook pro duo UX581gv battery ATM. I've had a google around filtering for Australian only but most of the sites look dodgy as hell hiding pricing and requiring you to put in all your details and get account approval before you can even see stock availability and pricing. Or their eBay/the other usual sketchy almost certainly counterfeit stuff. I did find the Samsung spare...
        07-10-2022, 05:17 AM
