Hello everyone, i'll do my best to explain my quandary.
I am trying to repair my wife's older 20" iMac G5 (powerpc) unit as she tends to use it sometimes as a desktop for light browsing and such.
I did end up buying another identical iMac as her's for parts as I broke a cable and it was cheaper to buy a whole system than just the cable.
I took both units apart as I am aware that these units tend to overheat, have PSU issues and capacitor swelling.
The original iMac we have, it was made in the USA back in 2006. The spare unit I purchased was made in China in 2005.
Here is what I've found.
The unit from USA has a good PSU, can't see any swelling on the capacitors. The unit from China has swollen caps on the PSU. Not that this is a huge thing as the PSU is probably made in by the same manufacturer, but I will look into that closely in a day or so.
The motherboards...aka logic boards is where I am stuck with.
The motherboard from the USA system had two bad capacitors. The unit had stability problems and the fans would seem to be running crazy loud and the CPU temps were around 80 degrees Celsius... see my video clip:
https://www.youtube.com/watch?v=TisjOJn7Z8M
The second spare unit, I was able to power it on and it worked fine once we tossed in a hard drive. The CPU temps were around 50 degree Celsius...much better then the other unit.
I've been set on using the keyboard from the spare Chinese made iMac...since it resulted in lower temps and seems like a safer bet.
Now onto the capacitors, below is what is identified on the capacitors themselves.
MCZ 6.3v 1800uF (1 total, 1 is bad)
MCZ 16v 1000uF (4 total, 2 are bad)
My question is, should I replace only those that are bad...are all of the capacitors?
Also, as I am new to this and I would like to learn and do this myself...can somebody explain on how I can choose the right capacitors for this iMac? I am aware of digikey site from other searches here but I am unsure how I can select the correct capacitors.
Attached are the photos.
Thank you kindly :-)
