Caps compatible issues
  • n1kstr3r
    • Dec 2015
    • 6
    • India
    On samsung syncmaster 740n power board, three caps with 820uf 25v are bad. Can I replace them with 1000uf (M) 25v? 820uf 25v not available in the local market. If what I havr is not compatible, then what is the next best compatible caps can i use?
    • 31289
    Re: Caps compatible issues
    1000 is o.k. IF they fit.
    820 are probably smaller.
    dont forget they must be low-esr
    • n1kstr3r
      • Dec 2015
      • 6
      • India
      Does the (M) matter?
      They are B41827 EPCOS 85 deg Celsius.
        • 31289
        no, and if they are 85' then they arent low impedance - which may explain why they need replacing!
        i doubt those epcos caps are original!
        • n1kstr3r
          • Dec 2015
          • 6
          • India
          The replacement 1000uf are 85deg. the original ones which were on the board are CapXon GL 105deg Celsius. C 6 1 8 Vent 820uf 25V
          • bikkerss
            • Feb 2015
            • 12
            don't think it can be a problem
              So you put in General purpose cap instead of Low ESR type which is required by the Switching power supply.
                by momaka
                03-12-2025, 03:42 PM
              • SluggerB
                Can't find exact matching caps for replacements, what should I get to prevent video issues?
                by SluggerB
                I have an old Tivo. The Power Supplies are known to have caps that fail. Here are the caps that come with the original power supply:
                I could not find replacement caps with the exact same specs. I followed an online guide and recapped the power supply with caps with these specs
                The power supply now works, however the HDMI video is giving me eye strain. I don't know how a capacitor on a Power supply could impact an HDMI video signal, but it does, the Tivo interface has a flicker now and the color/brightness is off. So I want to get some new caps...
                04-05-2024, 07:47 PM
              • eryjus
                by eryjus
                05-10-2023, 11:21 AM
              • Paxman_Swede
                by Paxman_Swede
                Hello!
                01-14-2025, 09:51 AM
              • captain150
                by captain150
                03-16-2025, 07:34 PM
