Identifying bad cap(s) as the culprit - TEAC LCD
  • judgelj
    • Nov 2015
    • 4
    • Aus
    Ok so i've been reading around and i think i have a good idea of what is happening. Was hoping i could get some opinions from the experienced.
    My Teac LCD suddenly stopped turning on (red LED, wouldnt respond to remote). I gathered that if i unplugged the TV from mains power overnight, it became responsive and worked fine. After a period of time it would turn off and refuse to turn back on.
    So what i've established is that the TV needs to be unplugged from mains for it to work briefly. This to me seems like leaking capacitors, but then again i dont know a lot. What would be my best course of action? Change all the caps on the power supply?
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Identifying bad cap(s) as the culprit - TEAC LCD
    Could be a bad solder joint as well...
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • judgelj
      • Nov 2015
      • 4
      • Aus
      I've pulled the back off the TV, everything looks good from a glance. Ill pull the power board off and check behind. What is actually happening for the TV to switch on only after all residual power has been drained. Seems pretty consistent.
      • judgelj
        • Nov 2015
        • 4
        • Aus
        So im trying to replace all the caps on the board. Problem is i can't find a lot of them in store. Are there any rules for matching similar spec caps? Can the voltage/capacitance be different from what was on the board? Thanks
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
          by momaka
          03-12-2025, 03:42 PM
        • crosswinds
          Assistance with identifying replacement caps on ASUS P5VDZ-MX
          by crosswinds
          So, pulled a motherboard out from storage, was working when put away, wont post when I took it out of storage today.
          Since it was working, and it looks to be essentially time that killed it I figured its a good idea to replace the caps before digging further.
          Looks to be only good quality caps on this board, so might not be the issue. But it is closing in on 20 years now so, wont hurt i guess
          Its a ASUS P5VDZ-MX board.
          I would really appreciate some assistance on what the best replacement caps would be for these:
          Panasonic(M)...
          04-17-2024, 04:25 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • fl0w
          GeForce 6800GT recap, need help identifying caps and finding replacements
          by fl0w
          I just noticed that my Asus V9999GT (GeForce 6800 GT) had some swelling capacitors. I managed to identify the brown ones, which are Nippon Chemi-Con KZG series, 6.3V 820µF, which I plan to replace with this.
          But for the yellow ones, I guess these are Fujitsu caps, without being able to identify which series... A picture of the video card is attached to the topic.
          I need to replace:
          • 2x 2.5V 1500µF => I plan to use this
          • 2x 16V 330µF=> I plan to use this
          • 1x 6.3V 680µF=> I plan to use this
          Am I correct with the cap choices?
          Thanks for...
          10-02-2024, 11:28 AM
