Needing specifics here. Please advise.
  • Cyryl The Wolf
    • May 2006
    Replacing caps is no foreign concept to me. I've replaced scores of them...with used, same-rating caps that I can find in power supplies lying around my office, etc. It's worked well enough. I have boards running for 2 years after, etc...
    *presents wrists for the slapping while grumbling 'Hey. It's what I had."*
    That's the problem. Where the hell do I find the correct caps to replace...brand new? I'm aware that certain brands are better, etc. Everyone loves Rubycon, etc. Great.
    But I am not able to really find somewhere to buy them.
    The second issue is that I read about "Ultra-low impedence" and "High-ripple" and realize that people are replacing 820uf with 1500uf @ same voltage, etc. THAT is actually the bigger problem.
    Does it really matter? How do I know what I have to replace? It's not as if the cap says, "Hey! I'm high-ripple!" Y'know?
    Please give me a summary that I can work with...for the love of the gods! I once submitted a request for caps to this site about two years ago...but never received a reply of any kind. Figured I'd try the forums this time.
    Right now, I'm replacing the caps on yet another Intel board. This one came out of a Gateway. It's an Intel D865GLC/D865PESO board. (I generally regard it as the fore.) The Nichicon *shudders* 820uf 6.3v electrolytic caps between the CPU socket and the USB/Printer/PS2 ports as well as one other near the CPU Fan connector are all shot. Need to replace them.
    Otherwise... The board posts and operates. I just won't continue to wear it down under these conditions until I replace the caps.
    SUMMARY:
    1.) Do I need to concern myself with specific types of caps? (e.g. 'High-Ripple' or 'Low-Impedence', etc.)
    2.) Where can I buy the damn things? :P
    Also... I'm not against buying higher-quality caps if they're available...and reasonably priced. (More or less...)
    Pics to follow shortly. (Within 15 minutes.)
    Thanks in advance!
    Cyryl
  • Cyryl The Wolf
    • May 2006
    Re: Needing specifics here. Please advise.
    Ok. Here are the links. Hosted on my own server so I don't have to be a jerk and rely on other people for bandwidth. Don't worry. It's fast. Pics are 1280x1024. 393KB - 451KB. 3 pics total.
    http://stormhaven.servehttp.com/imag...nichicons1.jpg
    http://stormhaven.servehttp.com/imag...nichicons2.jpg
    http://stormhaven.servehttp.com/imag...nichicons3.jpg
    • Cyryl The Wolf
      • May 2006
      As an update... Would this be a suitable purchase?
      Yeah. I know. It only took me another minute of looking... But is it CORRECT?
      http://store.fundamentallogic.com/in...roducts_id=107
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Yes, however low impedance is not the same thing as low ESR.
        Too low of ripple capacity and the caps will overheat and die early.
        Too high an ESR and they won't do their job thereby allowing the system to run on 'dirty' power. (Full of voltage fluctuations.)
        Badcaps.net
        Digikey
        Mouser
        Farnell
        RS
        Wai Fong
        eBay
        capsmod.net
        Newark [Newark In One]
        Mann-Made Global Warming.
        - Dr Seuss
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Yes MBZ would be just dandy.
          - Dr Seuss
          • davmax
            • Dec 2005
            • 899
            Where to buy is found in this forum at: https://www.badcaps.net/forum/showthread.php?t=613
            Rubycon MBZ or MCZ
            Samxon GC or GD
            Both types can be had from forum owner Topcat for US residents. Just ask him for what you need.
            Outside US Big Pope can supply any need.
            Just PM the right one for you.
            160Gb WD SATAII Server grade
            Nvidia 8500GT 256Mb
            Samsung 18x DVD writer
            33 way card reader
            Windows XP Pro SP3
            17" Benq FP737s LCD monitor
            • Leung Kai-yan
              • Apr 2006
              • 32
              Dear Friend,
              Your can buy good capacitors from Hong Kong by mail. It is easy to find good capacitors which capacitances exactly match the replaced. This place has a list of good international shops selling good capacitors.
                by momaka
                03-12-2025, 03:42 PM
              • eryjus
                by eryjus
                05-10-2023, 11:21 AM
              • Paxman_Swede
                by Paxman_Swede
                Hello!
                01-14-2025, 09:51 AM
              • captain150
                by captain150
                03-16-2025, 07:34 PM
              • Foetuss
                Gigabyte GA-6OXT :: caps question
                by Foetuss
                Good evening
                I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                But I was also suprised about the bigger boys, which are 330µF 25V.
                Could it be they used 25V caps because they were cheaper / available at that time?...
                02-11-2025, 12:22 PM
