OST = I.q?
  • gdement
    • Jan 2007
    • 690
    OST = I.q?
    I found these caps on the input of a K7S5A rev3.1 board:
    The flip side shows these are OST RLP series capacitors. OST is often bad, but not nearly as bad as IQ. For some reason I can't fathom, they've revealed on this label that I.Q is an OST product!
    My guess is they improved their caps (somewhat) and changed their name to OST at that point.
    Intel Core i7-900 Desktop Processor Extreme Edition Series Datasheet
    The Intel Core i7-900 desktop processor Extreme Edition series and Intel Core i7-900 desktop processor series are intended for high performance high-end desktop, Uni-processor (UP) server, and workstation systems. Several architectural and microarchitectural enhancements have been added to this processor including four processor cores in the processor package and increased shared cache.
    The Intel Core i7-900 desktop processor Extreme Edition series and Intel Core i7-900 desktop processor series are the first desktop multi-core processor to implement key new technologies:
    10-23-2024, 02:56 AM
  • klebendes_etwas
    Search for: QSC K10.2 Circuit Diagram & Component Layout Overview
    by klebendes_etwas
    Hello everyone! :-)
    An acquaintance of mine works as a DJ in his spare time and brought me a defective QSC active loudspeaker (Model: K10.2) for repair.
    Error description: The device could not be switched on (after he lent it to another DJ).
    A visual inspection revealed an obviously blown fuse (F41) and a cracked thermistor (R41) on the mains filter board. A closer look at the amplifier board revealed two defective power MOSFETS (Q13, Q14) and other defective components on the +12VLOW rail.
    After replacing all the obviously defective components, the...
    09-21-2024, 04:00 PM
  • s_specialist
    Monster Abra A5 V16.7 SRKMA burned
    by s_specialist
    The south bridge (SRKMA) on my Monster Abra A5 V16.7 was burnt, causing a 1.8V short circuit to the chip. I installed a chip I bought from Aliexpress, assuming it was brand new, and the 1.8V output improved, but when I pressed the power button, it drew 0.03A and didn't start. I can measure 3.3V, 1.8V, and 1.05V on the chip. The BIOS has 3.3V on pins 1, 2, 3, and 8. When I pressed the power button, it drops to 3.3V. I get EC_RSMRST voltage from the IT5570E, but I don't have SLP_S4 and SLP-S5 voltages. I've written the bios files I could find, but I can't find anything. Is the integrated circuit...
    11-01-2025, 03:44 AM
  • questore
    XPS 13 9370 CMOS battery voltage always low
    by questore
    Hi Everyone,
    I have brought you a mistery item
    This laptop have come with some strange faults.
    1. CMOS battery was flat 0v
    Symptoms:
    - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
    Amp drawing was stuck at 0.005 milliamps.
    - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
    After inverstigation RTCD1 diode had a low value...
    09-30-2025, 05:47 AM
  • rumpumpel1
    ThinkPad E14 Gen 4 AMD NM-E501 dead
    by rumpumpel1
    I have an E14 Gen 4 AMD that shows no signs of life.
    When connected to the charger the board initially drew 30 mA at 10 V.
    The thermocamera showed a hot spot at one edge of the PD controller. I therefore replaced the PD controller, after which the board drew 5 mA at 20 V.
    Further investigation revealed that the power switch UT5 (NX20P5090UK) was not activated. The EN# signal is missing. This is supposed to be generated by the PD controller.
    From then on I started using the battery instead of the charger.
    With the battery the main power rail V9B+ is present...
    08-10-2025, 05:07 AM
