Ducati capacitors
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8715
    Ducati capacitors
    I was investigating an old broken audio oscillator. Upon opening, I saw an exploded cap:
    Ducati "Catalyt" (1960s?)
    It appears to be Ducati SSR Energia of Italy and still in business?
    Anyway I just got some really bad, irrelevant hits from Yahoo when I searched for Ducati ...
  • dragon3x
    by dragon3x
    power on.
    Here are some examples :
    switching supply area).
    than 6.3 V.)
    03-21-2025, 02:46 PM
  • slybunda
    AA and AAA battery charger capacitors?
    by slybunda
    hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
    it has inside:
    2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
    2 x 470uf 16v LZ105c branded as G.Luxon
    not heard of these brands are they any good?
    iv attached photos of the charger and the board inside for an idea on the type of...
    12-24-2023, 04:41 AM
    After all of...
    07-13-2024, 08:14 PM
  • Cama
    Solar Inverter - SMH-II - 2 missing capacitors
    by Cama
    I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
    My model is : EASUN SMH-II 7 KW
    Mother Board : P/N 18947-002401250250
    Maybe the EASUN SMH-II 4.2 KW have the same capacitors
    Thank you...
    09-12-2025, 02:50 AM
  • Ady2017
    Are there any datasheets available for Elna RJG capacitors?
    by Ady2017
    I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
    05-25-2025, 02:19 PM
