do electrolite caps fail from disuse?
  • jack black
    • Dec 2010
    • 37
    the reason i ask, the last recap job i did was in a VCR that worked fine 7 years ago and blew up immediately when plugged in after that hiatus.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    Re: do electrolite caps fail from disuse?
    Old electrolytic caps, yes. Modern ones *should* not...
      • 31278
      yes they should, it's in the datasheets.
      if you leave them too long wihout any power going through them they de-polarise and you have to re-form them.
      • jack black
        • Dec 2010
        • 37
        so, would it be wise to periodically plug in and turn on various electronic gear that is stored? say once a year?
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          As a tube radio restorer, I say YES, Yes, yes! Leave them running for 15 minute too. 5 years is OK with no power from my experience.
          Follow the white rabbit.
            by momaka
            03-12-2025, 03:42 PM
          • Sus256
            HISENSE 65E7KQ PRO - no boot
            by Sus256
            Hi all!
            HISENSE 65E7KQ PRO
            RSAG7.820.13512 - chassis
            MT9618BAATAB - cpu
            RSAG7.820.12059 - power
            HD650Y3U77 - panel
            KLM8G1GETF - emmc
            Replaced emmc.
            Terminal log
            UART
            AC_ON
            E-B
            FDE enabled
            06-01-2025, 02:11 AM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
