"ATWY" caps on ~2007 gateway
  • cruzinforit
    Rin is my waifu
    • Apr 2015
    • 22
    Hey guys, I pulled an ~2007 era Gateway system out of the closet. It has an AMD Athlon64 X2 +5200, and an ECS motherboard with "ATWY" caps on, which are reddish. None are bulging, but I'm considering cleaning up the system for re-use, and I want to know if it would be worth recapping it, or how bad these caps really aer. I don't recall seeing them on the list.
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: "ATWY" caps on ~2007 gateway
    They're TK. Reported to be bad here, even though not sure if they're the worst.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • c_hegge
      • Sep 2009
      • 5219
      Yup. TK indeed. It stands for Terrible Kapacitors.
      see https://www.badcaps.net/forum/showthread.php?t=8053
      and
      https://www.badcaps.net/forum/showthread.php?t=46383
      Bear in mind, though, that, if it's the board I'm thinking of, the chipsets fail on them sometimes too, as they have known manufacturing flaws which you can't fix unless you replace the chipset.
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
