Help identifying capacitor manufacturer
  • cage
    • Jun 2011
    • 23
    Can anyone help identify this capacitor manufacturer?
    There seems to be a 'ce su' and a circled m.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Help identifying capacitor manufacturer
    Thats a panasonic su series capacitor designed for audio uses great caps btw
    See plenty of them in technics amps they are good caps.
    • cage
      • Jun 2011
      • 23
      Thanks for the info. I've got a couple leaking on the board but wasn't sure who made these.
      This is in a piece of av gear.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ohh no never seen one fail before shame but does happen to even the good ones.
        • Prolog
          RTX 3080 FE Identifying capacitor
          by Prolog
          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
          I hope these photos make it clear which component I am referring to:
          (yes, the soldering is a bit botched from removing the blown one, I know)
          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
          12-01-2024, 08:27 PM
        • Ambro
          Help identifying missing smd capacitor for HP elitebook 840 g3
          by Ambro
          In an unfortunate mishap while attempting to read from the bios chip, one of the smd capacitors took flight and disappeared.
          I'm not sure how crucial this smd capacitor is, but it was a brown possibly ceramic one with no notable markings on it anywhere.
          I've attached a picture of where it's located on the board.
          Does anyone have an HP elitebook 840 g3 who might be able to aid me identifying this component. I'm not sure how crucial it is, but didn't want to risk it.
          Thank you for any help you can provide....
          09-09-2023, 06:21 PM
        • grimacelord
          Need Help Identifying Capacitor On Kar-Tech Versa Remote
          by grimacelord
          I have sort of a weird one here. This is the circuit board for a Kar-Tech VERSA remote. It's a wireless transmitter for crane and other heavy equipment.
          One of the capacitors have blown and I need help finding a replacement. The capacitors are 11.4mm x 6.6mm in size and the only imprint on them is "200mΩF", which I am assuming means 200 microfarads. There is no other markings on them. I have tried doing some searching on digikey and mouser, but I can't seem to find anything like this on there or I am inputting the wrong search parameters....
          09-08-2023, 09:28 AM
        • krob80
          PS5 Edm-010 No Power - Help identifying missing capacitor
          by krob80
          Hey everyone. I recently acquired a PS5 that is not turning on (no beep/power). PSU is good and there is no shorting on the 12V rail.
          It came with a Gen3 SSD installed so I feel that things went down hill for the previous owner when it was installed. F7003 was blown but there was nothing shorting to ground. I replaced the fuse but still no power (new fuse is still good for now).
          When connecting it to a bench power supply, it only pulls 10 mA (doesn't spike when first connected).
          I noticed that there are a couple capacitors missing from the Vcore power regulator (pictures attached)....
          05-15-2025, 04:24 PM
        • chunk69
          Looking for help in identifying Kuang Jin capacitor from PSU
          by chunk69
          Hi friends,
          I recently acquired an old PC power supply (along with several vintage motherboards from late 90s/early 2000s). The PSU was dead upon first test, but quickly identified the internal fuse had blown. I fixed that, re-tested and i'm pleased to report it seemed to work great after that - no obvious issues or reasons for the fuse to blow.
          Afterwards, I inspected the capacitors more closely and noticed one pair required replacement. They weren't in bad shape by any stretch of imagination, but one was slightly bulged, and I wanted to swap them out for good measure....
          12-06-2023, 04:35 PM
