TBOR caps on Monster AVS 2000 power conditioner
  • Cohibaman
    • Jan 2015
    • 66
    I just bought a NOS (new old stock) power conditioner, manufactured in 2007. Literally factory sealed and unused. I unboxed it and tested it to make sure it works. Everything checked out. I popped the hood to take a look inside and saw it has about 17 TBOR caps rated to 105C, ranging from 10uf to 220uf. How crappy are these caps and should I just go ahead and replace them right away?
  • japlytic
    • Oct 2005
    • 2086
    Re: TBOR caps on Monster AVS 2000 power conditioner
    I would recommend replacing them all with Japanese units.
    • Heihachi_73
      • 713
      TBOR (actually TWBOR) are crap; I had a D-Link router full of those and suffice to say, it did not work since half of them had vented or pushed up from the bung.
      Link with photos:
      https://www.badcaps.net/forum/showthread.php?p=285999
      • Cohibaman
        • Jan 2015
        • 66
        Done - replaced all with Panasonic FM and a few FC.
        Also, they had two 12V regulators on one somewhat substantial heat sink. Still, it got so hot that I had to pull my hand away. I added two smaller ones that all together, nearly double the size of the original. So...what the hell were they thinking putting the cap bank RIGHT next to a blazing hot heat sink?
          • 31281
          that's the work of satan's school of electronic design - i'v seen it a lot.
          it's either very clever - and evil or very stupid.
          what will happen is the heat will dry out the cap, but because caps look better when they are warm you wont realise anything is wrong until you power it down one day and let it cool.
          then it wont work again.
          • Cohibaman
            • Jan 2015
            • 66
            Originally posted by stj
            ...it's either very clever - and evil or very stupid.
            I think a little of both unfortunately
            • Agent24
              I see dead caps
              • Oct 2007
              • 5085
              • New Zealand
              I think it's called too much theory in school and not enough practical experience.
              -David VanHorn
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                monster stuff is overpriced underperforming hyped up junk so this does not surprise me.
                • Cohibaman
                  • Jan 2015
                  • 66
                  Yep, I agree. But I got it for cheap and this one actually does what it claims. Basically it's an automatic variac.
                    by momaka
                    03-12-2025, 03:42 PM
                  • eryjus
                    by eryjus
                    05-10-2023, 11:21 AM
                  • Paxman_Swede
                    by Paxman_Swede
                    Hello!
                    01-14-2025, 09:51 AM
                  • captain150
                    by captain150
                    03-16-2025, 07:34 PM
                  • Foetuss
                    Gigabyte GA-6OXT :: caps question
                    by Foetuss
                    Good evening
                    I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                    Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                    But I was also suprised about the bigger boys, which are 330µF 25V.
                    Could it be they used 25V caps because they were cheaper / available at that time?...
                    02-11-2025, 12:22 PM
