Help identifying brown "LE" caps?
  • treblemaker
    • Nov 2007
    I was not able to find anything matching these caps in the good/bad cap threads or by searching the forums -- I'm sorry if I've overlooked something obvious, though...
    I have a fairly old but functional Tyan 2505 (dual 1GHz P3). It consistently fails memcheck86 test #5 (block move). All other POST and memcheck tests pass. But it seems to be getting more unreliable so I thought I would take a look at the power supply and caps.
    From what I've been able to find on the forums here it looks like most of the smaller caps are Rubycon ZL. But aside from one pair of OS-CON caps, most of the larger caps are brown plastic, labeled "LOW ESR" on one side and "[LE]" (letters inside a rounded rectangle) on the other side. (They do not look at all like the pictures on the Nichicon LE datasheet.) The pressure relief is a stylized "H" (or an "I", perhaps, if you look at it sideways...)
    A picture is attached.
    Does anyone have an idea what the manufacturer might be?
    Thanks and Best Regards,
    T.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Help identifying brown "LE" caps?
    maybe jamicon?
    first thing i would do is clean that filthy thing esp the dimms and sockets.
    i have simply cleaned up many "bad" dimms and restored normal operation.
    not saying the caps cant be bad but unless you have a scope or esr meter leave them for last as replacement is the easiest way to test without equipment.
    • linuxguru
      • Apr 2005
      • 1564
      Yup, probably Jamicon (not too bad) or Choyo (bad) or Hermei (really bad).
      • Big Pope
        Approved Vendor
        • Dec 2005
        • 426
        I guess it is the brand before "GSC", just like "GSC" changed to "Evercon" now.
        However, the product series never changed till to now, still call "LE".
        My SAMXON Capacitors Database HERE!!
        X-CON is a new brand for SAMXON's Polymer Capacitors.
          by momaka
          03-12-2025, 03:42 PM
        • crosswinds
          Assistance with identifying replacement caps on ASUS P5VDZ-MX
          by crosswinds
          So, pulled a motherboard out from storage, was working when put away, wont post when I took it out of storage today.
          Since it was working, and it looks to be essentially time that killed it I figured its a good idea to replace the caps before digging further.
          Looks to be only good quality caps on this board, so might not be the issue. But it is closing in on 20 years now so, wont hurt i guess
          Its a ASUS P5VDZ-MX board.
          I would really appreciate some assistance on what the best replacement caps would be for these:
          Panasonic(M)...
          04-17-2024, 04:25 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
