Glue on the vents...
  • Tom41
    • Oct 2005
    • 336
    • England
    I know that many PSU manufacturers put glue on the components inside, apparently to minimise vibration as the electricity flows through them. Most of the time this glue is around the base of the components - however, I've seen several with the glue on TOP of the capacitors! Often it's like a string of glue from a glue-gun over all the caps, but I've also seen caps completely covered in glue, and even once a small plastic sheet glued to the top of the vents!
    Is this anything to worry about in PSUs? Will the glue have sealed the vents and make any failure more violent? Will it make the caps more prone to overheating and other failures?
    Here's a picture of the kind of thing I mean in one of my PSUs:
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • Tom41
    • Oct 2005
    • 336
    • England
    Re: Glue on the vents...
    Sorry for double post, edit time limit expired. Here's the glued plastic sheet vents that I mentioned earlier:
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      well the inductors could need it. the caps you could definitely remove it. i guess they just tell the guy with the glue gun to get anything standing up
      yeah i think the caps more likely to blow their bungs out like that. heating i dunno, if its only partially covered then ok, ripple is less your friend than heat anyway.
      • Tom41
        • Oct 2005
        • 336
        • England
        I was talking to some friends on AIM recently, who are into electronics. Apparently the plastic sheet that's glued over the big caps is to provide insulation. The tops of those caps will be at mains voltage, and you wouldn't want to touch them while the PSU is on! Likewise, if something conductive falls into the PSU it may conduct the mains voltage to the chassis or something else, causing a shock hazard.
        That's exactly why the caps used in the input section usually have a plastic-covered top, to provide insulation. Using normal caps with exposed metal tops, then sticking a piece of plastic over them is a sign of shoddy PSU design/manufacture.
        That at least explains the glued-on plastic on the input caps, but I still can't understand why they put the glue on the caps in the output section on that HP PSU. Those caps are more likely to be at a lower DC voltage (12v or 5v), so shouldn't cause severe shocks if touched.
        • Krankshaft
          • Jan 2007
          • 2328
          I think that the reason they glue the secondary caps is because after they are inserted by machine the glue prevents the caps from falling over or out before the wave soldering process.
          The glue solidifies them as a unit.
          And don't forget some parts on certain boards still need to be inserted by hand before the wave soldering process and if the assembler turns the board over too much there goes all the caps.
          Also I have a supply with that plastic cap over the line filters too and its a Bestec power supply that HP uses regularly so I guess its not only cheapies that use that trick.
          The problem is they use high voltage radial caps for the input filters if they used radial snap-ins the metal vents of the caps would be covered and this plastic piece wouldn't be needed.
          An example of these caps is at this link:
          http://www.41hz.com/main.aspx?pageID=153
          I always use the Panasonic radial snap-ins in place of the radial line filters that come with the supply I simply bend the snap in leads down clip the old leads off the old cap and solder them onto the radial and the old caps legs back onto the PCB.
          • Krankshaft
            • Jan 2007
            • 2328
            Sorry about the second post that 10 minute edit thing is annoying.
            Anyways the above trick works great on LCD inverter supplies where space is limited and the line filters are ALWAYS bent on their side.
            I also have not seen a single LCD inverter where the line filter cap hasn't had glue under it to hold it down.
            Which strengthens my theory that its purpose is to keep the caps from falling off.
            As for the glue reducing the caps ability to vent that all depends on the melting point and the strength of the glue to resist stretching and pressure.
            • gonzo0815
              • Feb 2006
              • 1600
              Most of this kind of glue is not very hard or strong. So i would guess, that the material at the vent will certainly still rupture.
              The glue can?t seal the cap, if even the tiniest whole is in there. Hydrogen isn`t easily sealed away.
              May be the pressure would become a little higher, but probably not that significant.
              I see only a problem with very strong glue like epoxy or similar.
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • mitsu2k
                The Real Dangers of conductive glue.
                by mitsu2k
                I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
                Here is an experience I...
                04-16-2023, 06:29 PM
              • harp
                Metod for removing glued heatsink from fragile component
                by harp
                I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
                06-23-2025, 02:01 PM
              • AJ847.63e
                Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                by AJ847.63e
                Hi Folks,
                Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                05-06-2025, 10:37 PM
              • dreamlayers
                Weird clipping on Logitech Z-10 speakers
                by dreamlayers
                I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of...
                05-22-2025, 11:41 AM
