Replacing ceramical with electrol. capacitor
  • zeljko
    • 8
    • serbia
    Little bit of help from my friends !
    Old fujitsu -siemens LapTop c-series 1020, blown ceramical capacitor. According to a block diagram ( c31 4.7 uF 25v )
    Question : can I replace ceramical ( non polarised ) capacitor with electrolit. or tantalum polarised capacitor with similar values ( for example 6.8uF 50v).
    Thanks in advance.
  • CapSwapper
    • Feb 2014
    • 69
    Re: Replacing ceramical with electrol. capacitor
    why would you do that. ceramic capacitors don't bulge and die and usually last forever
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Yes it can be done...Take two Electrolytics and join the +ve leads together so that the two -ve leads are free for soldering........You can also try a non-polarized cap...the kind used as filter caps in tweeters. The better thing though is to get an original ceramic cap to replace your bad cap.
      • zeljko
        • 8
        • serbia
        Thanks, for replay CapSwapper. The answer is : I have no time (patience ) to wait for delivery.
        Last edited by zeljko; 01-15-2015, 04:06 AM. Reason: Forgoten name to whom I replay.
        • zeljko
          • 8
          • serbia
          Thanks Andrew, that is the answer I've expected.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            No need to do that if the ceramic capacitor was originally sitting on a DC rail. In that case, you can just use any polarized capacitor just fine.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              And almost all circuits in laptops are polarized, so if you respect the polarity it will be just fine. Measure with your multimeter to any screw hole, the side that reads 0 will be the ground/negative.
              I would recommend you to use a tantalum cap instead of an electrolytic for ESR and ripple handling reasons.
              A working TV? How boring!
              • zeljko
                • 8
                • serbia
                Thanks for replies, I'm not a pro, I have basic knowledge of electronics. My dilemma was polarity. On schem. I cannot see polarity, so safest way is to solder non-polarised capacitor ( original or made one ).
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  Use your multimeter to check it.
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    ^Yes.
                    Set your multimeter to the lowerst resistance setting (200 Ohms on a manual meter... if you have auto, then no need to do this). Now touch both of your multimeter leads together and see what resistance the multimeter shows - this is the lowest resistance it can measure and can be assumed as a short for all practical purposes. On most decent multimeters, it should be less than 1 Ohm (0.7 Ohm to 1.5 Ohm is typical for cheap manual multimeters).
                    Now see which side of the cap lead measure that same low resistance - that would be the one that is connected to ground.
                    • ki8du1
                      • Feb 2015
                      Thanks in advance.
                      Thanks for the Post
                      • zeljko
                        • 8
                        • serbia
                        You're welcome!
                        • MORETTIGIAN
                          Capacitor detached from PCB – RTX 2070 Super Founders Edition
                          by MORETTIGIAN
                          Title:
                          Description:
                          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                          I did not notice it detaching, so I am unsure of its original location on the PCB.
                          Procedure performed:
                          - Removed backplate
                          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                          - Reapplied thermal compound
                          - Reassembled card
                          Observed behavior after reassembly:
                          - GPU powers on and operates normally under...
                          09-18-2025, 12:14 PM
                        • chth96
                          If I replace with inferior capacitor, Is it No harm to other IC components at all?
                          by chth96
                          I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                          Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                          It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                          So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                          I know that these capacitor will not last as long as nichicon capacitor...
                          12-22-2023, 04:34 AM
                        • chth96
                          How can I test non-polarized capacitor?
                          by chth96
                          I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                          I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                          And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                          I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                          06-02-2024, 07:31 PM
                        • chth96
                          Is it no harm to replace with capacitor without ripple current rating?
                          by chth96
                          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                          Rubycon YK DataSheet (b...
                          04-19-2024, 05:19 AM
                        • chth96
                          Should I replace polymer capacitor?
                          by chth96
                          a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                          I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                          Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                          Is this ESR value of polymer capacitor correct?...
                          11-18-2022, 04:22 AM
