Can I replace a 1000uf 6.3v for a 1000uf 10v cap?
  • mmouse
    • Dec 2004
    mouser is out of the 6.3v caps so is it ok to use a higher voltage raided cap?
    http://www.mouser.com/index.cfm?hand..._pcodeid=64712
    also these are good cap's right? low esr's??
    I heard when replacing the cap's alsmot alwsy try to keep the UF the same but the voltage can be higher as thuis shouldnt have any effect on the circuit?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    it will be ok if it is small enough to fit.
