Trouble reading this blown capacitor
  • badnocap
    Cappy a Baddy
    • Jun 2025
    • 12
    25V 470uF? Any help would be appreciated! This was in an Adam A7X speaker. I replaced with a different uF and voltage closest to the values I thought because it is all I had in stock. It restored the speaker to working condition but it is certainly not what I needed to do as it is putting out less volume than its sister speaker which presumably no issues.
  • R_J
    • 9621
    470µf / 25Volt
    • badnocap
      Cappy a Baddy
      • Jun 2025
      • 12
      Originally posted by R_J
      470µf / 25Volt
      Thank you for confirmation. Unfortunately this will mean a specialty order but one that is necessary! Thanks again!
      • R_J
        • 9621
        I'm sure whatever you replaced it with is fine, you likely have other problems than just this cap, for a cap to blow like this is usually reversed polarity or too high a voltage or it internally shorted.
        • MORETTIGIAN
          Capacitor detached from PCB – RTX 2070 Super Founders Edition
          by MORETTIGIAN
          Title:
          Description:
          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
          I did not notice it detaching, so I am unsure of its original location on the PCB.
          Procedure performed:
          - Removed backplate
          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
          - Reapplied thermal compound
          - Reassembled card
          Observed behavior after reassembly:
          - GPU powers on and operates normally under...
          09-18-2025, 12:14 PM
        • MeetingIncapable
          Blown capacitor repair on MSI Radeon RX 5700 XT MECH OC
          by MeetingIncapable
          I am new to repairing computer electronics, so excuse any mistakes I make.
          A friend of mine had a broken graphics card (MSI Radeon RX 5700 XT MECH OC) and gave it to me. It does not power on or show any signs of life.
          I identified what looks like the remains of a blown capacitor at the bottom of the board (see picture).
          I wanted to replace the capacitor, but I have two questions:
          • Does this repair have a chance of working? or is a blown capacitor a sign something else is wrong?
          • How do I determine the rating/value of this capacitor? or something
          05-04-2024, 09:56 AM
        • NuclearSpartan
          Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
          by NuclearSpartan
          I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
          The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
          I don't see any other visible damage anywhere else on the board....
          11-14-2024, 02:32 PM
        • Fuzzy Fix
          0.00 ESR reading on a capacitor
          by Fuzzy Fix
          Howdy all I have a 90uF Capacitor 200/275 VRMS and measured the ESR . Reading says 00.3 Ohms and about 1/2 a second later 00,0 and says low ESR (Really No Kidding).
          I have checked it on the multimeter and reading is 94.7uF well within soec as ir has a 25% tolerance on it.
          Can anyone advise me is this capacitor likely to fail in the near future or still good to use.
          07-26-2024, 12:05 AM
        • expertreader
          Found a blown capacitor - is it necessary to replace?
          by expertreader
          Hi all, Acer Nitro 5 - GH51M LA-K862P Rev 1A motherboard. I went through all the troubleshooting steps but couldnt find a short on any coils. By chance, ended up finding a blown capacitor PCZ49 which is suppose to be 2.2uF. I can see plenty of 2.2uF in the same +5VALW line which will all parallel up anyway - do you guys think it is critical for this cap to be replaced or i can get away without one?...
          10-15-2025, 04:54 AM
