Most MCZ (and MFZ) I found on eBay were genuine, but rather old stock.
The 6.3V ones may indeed be a bit "unstable", especially used ones pulled from old boards, and also if they have sat unused for very long... at least that's my personal experience.
MBZ, on the other hand, seem to hold up OK. Haven't had issues with any yet.
That said, Panasonic FR, FM, and FS along with UCC KZH and KZM and Nichicon NV/HW can often be "good enough" for most motherboard use cases.
Nvidia 790i Ultra Bad Caps Causing Problems?
MBZ / MCZ have not been made for many years now,
any for sale are fake or ancient
I wouldn't really recommend MCZ as they have unstable electrolyte like KZG and typically don't last very long. Some short out without signs of damage, but I haven't experienced that, just very vivid deaths.
Purchased a 790i Ultra, the seller replaced 4 caps with new ones and possibly higher values and now the board won't fit long GPUs anymore in slot one, original values unknown. Can anyone help identifying voltage and capacitance of the four highlighted in red below?
The caps in question are:
C4J12, C4J13, C5J3 C5K2 located immediately behind the floppy connector.
Thanks in advance.
Re: Nvidia 790i Ultra Bad Caps Causing Problems?
Cheers, ordered 15 from badcaps last night, thought id order a few extra as this seems like a common problem with these boards.Leave a comment:
Anything in the UK you can recommend?
RS Online has a UK branch too.
http://m.rs-online.com/h5/mobile/uk/...um-capacitors/
HOWEVER
There are a few series which are not ideal replacements but might just be close enough. Panasonic FM series is probably the closest in terms of electrical specifications, but, like the Ruby ZL you were considering earlier, it is physically a few mm larger in diameter, so you may have a hard time squeezing some of them in.
Since the caps in question do appear to be used for VRM filtering, you could probably poly-mod the board using lower capacitance (like 820uF) solid caps such as Nichicon FPCAP L8, which are the correct diameter. I've had pretty good luck poly modding motherboards in the past like this, but be warned that it is experimental and I don't by any means guarantee that it will work.Last edited by c_hegge; 09-23-2014, 02:45 AM.Leave a comment:
http://m.rs-online.com/h5/mobile/uk/...um-capacitors/Leave a comment:
Rubycon ZL? No. They are too high ESR. Farnell do not have anything suitable for this application (although a panny FM might just be close enough if you can squeeze a physically larger cap in). Use https://www.badcaps.net/store/produc...products_id=39 from badcaps.netLast edited by c_hegge; 09-22-2014, 03:45 PM.Leave a comment:
http://uk.farnell.com/jsp/search/pro...sp?sku=1144672
As above will these caps do?Leave a comment:
High failure rates are mostly with 2.0+ VDIMM and with DDR 2 Micron D9s.Leave a comment:
I didn't mean that. I assume that the board is to be recapped first before making voltage adjustments.Leave a comment:
RUBYCON - 6.3ZL1500MEFC10X20 - CAP, ALU ELEC, 1500UF, 6.3V, RAD (ZL Series)
guys would the above be suitable as a replacement to the Sanyos?
Ive got another board with the exact same caps leaking on themcant be arsed waiting 2 weeks for the MCZ from eBay China, these are local to me so can pick up. Well anything from Farnell will do as is local to me.
Hi, Yes replaced them yesterday and have not had a crash since.
Big thanks to all you guys for the advice and help, that's two things fixed now thanks to this board!Last edited by mikay786; 09-06-2014, 08:29 AM.Leave a comment:
Did you end up replacing them, if so did it fix the problem ?Leave a comment:
Should I replace all 5 of the Sanyos? 1 of them seems ok but since I have ordered 5 Rubycon and there are 5 Sanyo caps?
Also after reading around 1.5v seems quite low for DDR3 boards back say 2008 when the 790i came out. Ive read a few places saying low voltage stuff can cause issues on the 790i and to bump up the Ram volatges especially when using 4 sticks.
I bought the system second hand for not much money and unfortunately reset the CMOS so didn't get a look at the voltages set for the RAM (although since they are the original sticks you would imagine dell would have programmed that into the bios)
Noticed the caps had discharge on them so stripped the system, completely forgot about trying to up the voltages on the RAM but I guess this needed doing anyhow.
Will see anyhow once new caps arrive.Leave a comment:
I would not recommend increasing the voltage unless recapping doesn't help. I think you're board only plays up because it's an ASUS and probably has a cheapped out VRM.Leave a comment:
Sanyo WG capacitors are actually very pristine as far as their known track records go, I haven't heard or seen any fail other than from discolorating levels of heat. It's Sanyo WF that's known to fail and that's what the OP's board has. I'd say those were indeed causing the issues in question, but I wouldn't say the power supply is quite built like a tank... it does look like a very nice Hipro save for the CapXon HP primaries which in the application of APFC will eventually fail so those should be taken care of too.Leave a comment:
Sounds like maybe undervolting, and with 4 sticks, I would bump it to 1.65 V. Sounds like it may be acting up like DDR 2 does.Leave a comment:
Those caps on amazon are very very very likely FAKE. Do NOT use them in anything you care about! Chances are, they will not last long at all and you will need to recap the board again (or worse, they could go so bad that they could kill a MOSFET).
Actually, those Sanyo's that are originally on his board right now could well be genuine. IIRC, it was mentioned on badcaps a few times that WG series aren't very stable.
I actually think those are genuine sanyos. The covers have the faded printing that you see on genuine ones. And OEMs typically have sources to genuine parts.
--> it seems like there's a lot of blame for OEMs using fake capacitors, when this is simply not the caseLeave a comment:
This specification for the LG Gram Ultra-Lightweight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Lightweight boardview and Ultra-Lightweight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 03:40 AM
This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 03:40 AM
This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 09:10 PM
- Loading...
