I got bad CAPS!
  • Shimen
    • Jul 2007
    • 16
    I got bad CAPS!
    Good to have found this site so thanks for making it anyway. I got a Gigabyte GA-7DXR that has 10 bad caps on it. I Found your site while looking for a place to buy this things and well honestly the sites are confusing for me. I can replace the things quite easily but im having a hard time finding the ones i need. The 10 that are bad are a 1200UF 6.3v caps. If anyone is familar with this MoBo they are the green ones that are right around the ECU. The black ones rated at 25v are not leaking or bubbling they still look brand new. So a favor to ask someone.... please help me find the caps i need. I want a good brand by the way. I need my comp up an running ASAP. There is to much info that can not afford to be lost. Thanks for anyone that helps me.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: I got bad CAPS!
    Replace all caps of the same make
    Topcat (owner of this site) can sell you caps
    Or if you are not in the US you can ask Big Pope on these forums, he can sell you Samxon caps
    • Big Pope
      Approved Vendor
      • Dec 2005
      • 426
      Re: I got bad CAPS!
      Where is your location? Please read this thread first if possible.
      https://www.badcaps.net/forum/showthread.php?t=2928
      My SAMXON Capacitors Database HERE!!
      X-CON is a new brand for SAMXON's Polymer Capacitors.
      • Shimen
        • Jul 2007
        • 16
        Re: I got bad CAPS!
        I am located in Indiana. South of indianapolis, I looked at that earlier. How would i go about buying from you.
        • Shimen
          • Jul 2007
          • 16
          Re: I got bad CAPS!
          And Hansson are you saying to replace all the caps regardless of wether or not they are bad. IF so i got a bit of work to do . Thanks
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Re: I got bad CAPS!
            Normally you will need to replace all caps above 470uF of the same manufacturer
            Unless the fault was for a very specific reason and you can be confident the other caps will not fail...
            What type of caps are on the board? Do you have pictures. It really helps in making informed advice... Also note that your power supply could have bad caps!
            • Shimen
              • Jul 2007
              • 16
              Re: I got bad CAPS!
              Wow power supply huh well i guess i will need to get a list together of all the caps on my board and also open up my power supply. The caps are some funky manf.. like Choyo i think. And if i was at home and had my comp up and running i would have pics but since i have only one computer no pics sorry. I will see if i cant get a pic of the board and post it. At least so i can show you guys which caps have gone bad.
              • Shimen
                • Jul 2007
                • 16
                Re: I got bad CAPS!
                No bad caps in PSU. So just on the board all the other caps on the board are 440uf or below.
                  by momaka
                  03-12-2025, 03:42 PM
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • captain150
                  by captain150
                  03-16-2025, 07:34 PM
                • Foetuss
                  Gigabyte GA-6OXT :: caps question
                  by Foetuss
                  Good evening
                  I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                  Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                  But I was also suprised about the bigger boys, which are 330µF 25V.
                  Could it be they used 25V caps because they were cheaper / available at that time?...
                  02-11-2025, 12:22 PM
