Aliexpress capacitors?
  • Mattz_GT
    • Jan 2025
    • 19
    Good, bad, fake or pot luck?
    I know, if they claim to be a name brand but are too cheap, most likely fake, but if not branded?
  • andrewsawesomr
    • Jun 2022
    • 100
    • United States of America
    I wouldn't, I've seen many cases where the caps are rated for a lower voltage than what they print on the sleeve and will explode if exposed to voltage printed on the sleeve
    https://www.eevblog.com/forum/projec...gx-capacitors/
    Any reason not to order from DigiKey, Mouser, CPC Farnell, RS Components, or LCSC (for electrolytic cap brands on LCSC I choose Cornell Dubilier, Kemet, Kyocera AVX, NCC, Nichicon, Panasonic, Rubycon, Suncon [not Su'scon], Taiyo Yuden, TDK, Vishay Intertech. and Yageo) (for polymer, you can use just about anything on there with a datasheet).
    • andrewsawesomr
      • Jun 2022
      • 100
      *The last paragraph was supposed to end with a question mark
      • Hitto
        Fake Nichicon capacitors with almost-perfect sleeve?
        by Hitto
        Fake Nichicon capacitors with an almost-perfect sleeve?
        Same font, perfect logo, same size of the sleeve. The air vent looks okay. The diameter of the capacitors is correct per datasheet.
        It truly looks like the real thing.
        I doubt that you would distinguish it from a genuine one.. if it wasn't for the bung.
        Shall we be afraid, at this point, that even the bung can be replicated?...
        01-09-2021, 03:07 PM
      • Olkus
        Elna capacitors - fake?
        by Olkus
        I have capacitors like this one in the photo. There are differences between other Elna series, I attach foto of Elna RE3. On this green capacitors series is not specified! Fake?...
        09-01-2023, 02:45 AM
      • dragon3x
        by dragon3x
        power on.
        Here are some examples :
        switching supply area).
        than 6.3 V.)
        03-21-2025, 02:46 PM
      • slybunda
        AA and AAA battery charger capacitors?
        by slybunda
        hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
        it has inside:
        2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
        2 x 470uf 16v LZ105c branded as G.Luxon
        not heard of these brands are they any good?
        iv attached photos of the charger and the board inside for an idea on the type of...
        12-24-2023, 04:41 AM
        After all of...
        07-13-2024, 08:14 PM
