NV-V8000 vcr caps change
  • Thermaltake
    Brain badcap
    • Aug 2015
    • 332
    • D12
    Hi, I am restoring my NV-V8000, and wondering there is 16V 4700uF cap near transformer, is it low esr one or normal one ? On PSU they are all replaced with low esr, but I am not sure about that one near transformer. I tried to google and look at manual but I couldn't find anything.
    • 31051
    hard to say without a schematic.
    try rubycon YXF series.
    they are high temperature long-life caps with a slightly low esr without being extreme like FR or ZL's
    • Thermaltake
      Brain badcap
      • Aug 2015
      • 332
      • D12
      I have Nippon KYA are they too extreme for that ?
      If it's not a problem can you take a look at manual I upload it for you (it's a bit big 155MB), I couldn't find myself.
      Code:
      https://mega.nz/file/49QSnJbB#dKmndz_Y1U8iJnWTC5r8HlwbxGtFSJ8vkc-ju2a3OCQ
      here is how the situation looks like, I will only change this big one, little ones I won't touch.
        • 31051
        thats linear, any high temperature longlife cap will do.
        but the small ones are the ones you need to replace first - they dry out faster
        • Thermaltake
          Brain badcap
          • Aug 2015
          • 332
          • D12
          Would transformer perform worst or something if I put low esr on both little ones and big one ? Or it's recommanded to put normal 105C caps on all ?
          • Thermaltake
            Brain badcap
            • Aug 2015
            • 332
            • D12
            I order that big one 25V 4700uF normal esr. But those little ones6.3V 47µF, 25V 33µF, 6.3V 100µF, 16V 47µF, 6.3V 100µF, and 16V 33µFI couldn't find normal esr they are all low esr.
            Also there is lower board I think it's servo board (VJB06704), don't know if you saw it in manual. I assume that board is controling timings and stuff like that, and caps should be normal esr, am I right ?
              • 31051
              i use low esr for everything,
              but when your talking about anything over 2200uf there is a noticeable price difference for low esr caps
              specially stuff like these:
              https://uk.rs-online.com/web/p/alumi...citors/7441256
              • Thermaltake
                Brain badcap
                • Aug 2015
                • 332
                • D12
                I already have at home low esr. I order normal one for that 4700uF that you told me should be normal, they are not expensive here in Croatia. So I will put normal esr then for that 4700uF, and little ones low esr, because I couldn't find that little ones in normal esr.
                Also question along with this one from thread. In my JVC on main I will put low esr but on REG section is it ok to put low esr or should I put normal caps ?
                  • 31051
                  regulators need low esr,
                  infact most datasheets recomend using tantalum on the output pin.
                  • Thermaltake
                    Brain badcap
                    • Aug 2015
                    • 332
                    • D12
                    Ok. Thanks for clarifying that, because chatgpt told me I need to put their normal esr caps...
                    So what about transformer is it ok to put normal esr for big 4700uF and little ones low esr ?
                    This is board of my S7960
                    Click image for larger version  Name:	2.jpg Views:	0 Size:	2.84 MB ID:	3551609 Click image for larger version  Name:	1.jpg Views:	0 Size:	4.54 MB ID:	3551610
                      • 31051
                      the transformer is running at mains frequency's so it wont stress the caps - 100-120Hz.
                      low esr is needed up in the KHz range.
                      as for chatGPT, forget it.
                      all these so-called AI systems "learn" by trawling the net and some social media.
                      and we all know how much shit is out on line!!!
                      • Thermaltake
                        Brain badcap
                        • Aug 2015
                        • 332
                        • D12
                        Thank you for Your help
                        • R_J
                          • 9551
                          I see you are working on two vcr's, The JVC vcr has a SMPS, after looking at the service manual for the panasonic, C1003 is just for the linear power supply like stj said. so no need for low esr
                          • Thermaltake
                            Brain badcap
                            • Aug 2015
                            • 332
                            • D12
                            Yes I am hobbiest, love to repair stuff. Actually 3 VCR's. 1. S9760, 2. S9850 and NV-V8000
                            Thanks for the help
                            I just google one of that Lelon cap. in REG section on my S9760, and it's saying in specifications that it's standard cap. It's not same value as mine, but tags on it are the same.
                            Code:
                            https://powerfulsound.com/product/lelon-rea-22uf-450v16x25mm/1546/
                            • Thermaltake
                              Brain badcap
                              • Aug 2015
                              • 332
                              • D12
                              Correction it's S7960.
                              So it's safe to replace all that caps. in REG section and that one near buttons with low esr ?
                              • Thermaltake
                                Brain badcap
                                • Aug 2015
                                • 332
                                • D12
                                Also I can't find in manaul on SysCon/Servo board on my NV-V8000 should I put normal esr caps or low esr I was reading that board is for timings and stuff. Does timing boards need normal caps instead of low esr to work normal ?
                                  • 31051
                                  timing is done by crystals not caps - luckily.
                                  • Thermaltake
                                    Brain badcap
                                    • Aug 2015
                                    • 332
                                    • D12
                                    Oh ok, I'm a hobbyist so I am still catching and learning. Thank you
                                    • Thermaltake
                                      Brain badcap
                                      • Aug 2015
                                      • 332
                                      • D12
                                      One more help.
                                      I was trying to look in my V8000 at capacitor physically in video board but it's deep under the doughter boards and I can't see it's values. In manual it's under C3768, can someone see in manual or find somehow the values ? I was looking but nothing in the manual seems to point out what value that capacitor is.
                                        • 31051
                                        got a link for the manual?
                                          by momaka
                                          03-12-2025, 03:42 PM
                                        • eryjus
                                          by eryjus
                                          05-10-2023, 11:21 AM
                                        • Paxman_Swede
                                          by Paxman_Swede
                                          Hello!
                                          01-14-2025, 09:51 AM
                                        • captain150
                                          by captain150
                                          03-16-2025, 07:34 PM
                                        • Foetuss
                                          Gigabyte GA-6OXT :: caps question
                                          by Foetuss
                                          Good evening
                                          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                          But I was also suprised about the bigger boys, which are 330µF 25V.
                                          Could it be they used 25V caps because they were cheaper / available at that time?...
                                          02-11-2025, 12:22 PM
