NV-V8000 vcr caps change
  • Thermaltake
    Brain badcap
    • Aug 2015
    • 339
    • D12
    Originally posted by stj
    got a link for the manual?
    I put link in Post #3
    Code:
    https://*******/file/49QSnJbB#dKmndz_Y1U8iJnWTC5r8HlwbxGtFSJ8vkc-ju2a3OCQ
      • 32068
      i have no idea what i'm looking for,
      which pcb and what else can you say?
      • Thermaltake
        Brain badcap
        • Aug 2015
        • 339
        • D12
        In manual, Page 127 MBO VEP07336 - C3768 position.
          • 32068
          c3768
          220uf 16v
          it's in the schematic on 126, a 12.1v to 9v regulator circuit
          • Thermaltake
            Brain badcap
            • Aug 2015
            • 339
            • D12
            c3768
            220uf 16v
            Damn I am blind.... thanks!
            Low esr can go there ? And on that board when I replace those big caps, can all be low esr ?
            • Thermaltake
              Brain badcap
              • Aug 2015
              • 339
              • D12
              #26
              I am curious because I am going to buy them, but not sure if they should be normal or low esr...
                • 32068
                low esr is fine - and longer lasting
                • Thermaltake
                  Brain badcap
                  • Aug 2015
                  • 339
                  • D12
                  #28
                  Thanks!
                  I calculated around 44 capacitors will be changed on vcr hope everything went well. I even corrected some factory faults on it, and now only cap changing is left. I'll let you know, and post some pictures if that's ok.
                  • Thermaltake
                    Brain badcap
                    • Aug 2015
                    • 339
                    • D12
                    #29
                    Update on my V8000.
                    Around 50 electrolytic capacitors​ were replaced plus some smd electrolytic caps too. Corrected a lot of bad solder on various boards in video section, they were the reason why front inputs were not working. Now everything is working as it should.
                      • 32068
                      what are you doing about rubber stuff like idlers and pinch rollers?
                      • Thermaltake
                        Brain badcap
                        • Aug 2015
                        • 339
                        • D12
                        #31
                        On V8000 there are not many rubber stuff, it's mostly mechanic. One belt which is okay I inspect it, and pinch roller which is also like new. I just refresh them a little.
                        But on my other VCRs I replace old rubbers with new one if they are broken or worn out.
