"R&C" brand capacitors
  • japlytic
    • Oct 2005
    • 2086
    Yesterday, I saw some bad "R&C" brand capacitors in a Conia CSTB303 set-top box.
    Are there any other sightings of this brand of capacitor?
  • Sereno011
    • Aug 2013
    Re: "R&C" brand capacitors
    Just did a repair on my Logitech LS21 2.1 speakers. All the caps were R&C brand. I've never heard of them before either. About a dozen total. None were bloated but half were bad with weak uF and high ohms (5-10ohms) and the the other half weren't far behind. None had less than 2ohms ESR, ranging from values of 47-220uF. Only a 7W speaker setup, ~5 years old and only ever use it at moderate volume so it's not like it was abused. Even some Chang caps would put these to shame. Absolute garbage!
    • dragon3x
      by dragon3x
      power on.
      Here are some examples :
      switching supply area).
      than 6.3 V.)
      03-21-2025, 02:46 PM
    • Stanley1843
      BEST 505 Vs Mechanic Brand Reballing Balls with Lead
      by Stanley1843
      has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.
      06-22-2024, 11:06 AM
    • slybunda
      AA and AAA battery charger capacitors?
      by slybunda
      hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
      it has inside:
      2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
      2 x 470uf 16v LZ105c branded as G.Luxon
      not heard of these brands are they any good?
      iv attached photos of the charger and the board inside for an idea on the type of...
      12-24-2023, 04:41 AM
      After all of...
      07-13-2024, 08:14 PM
    • Cama
      Solar Inverter - SMH-II - 2 missing capacitors
      by Cama
      I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
      My model is : EASUN SMH-II 7 KW
      Mother Board : P/N 18947-002401250250
      Maybe the EASUN SMH-II 4.2 KW have the same capacitors
      Thank you...
      09-12-2025, 02:50 AM
