Sck 054
  • crn
    • Jan 2014
    • England
    Sck 054
    SCK 054
    Does anyone know the value of this type of bead like capacitor. I have been told that it is a Thermistor cap but no thermistor that I can find looks like this one. This is the size of about 10mm across and is coloured green and looks like the blue type bead capacitors that are on most boards. This one had blown and I took it out of the power supply board and it had also blown the fuse. The board said RT1 just where I took this cap out of does this give some clue to the value of this SCK 054 type cap. Many Thanks for reply in advance Chris
  • R_J
    • Jun 2012
    • 9624
    Re: Sck 054
    It is a thermistor
    • lexwalker
      • Feb 2011
      • 307
      • Malaysia
      Re: Sck 054
      Originally posted by crn
      SCK 054
      That's a thermistor actually. Even the markings indicated that. Tracing the circuit around it would reveal its actual purpose. Most thermistors will have the appearance of a large ceramic disc capacitor, and is usually in series with the mains power line (always on the Live side) often just before the filter circuits. Also do beware of another type of component called varistors which also can look like a large ceramic disc capacitor, and is usually connected in parallel on the mains power lines (between Live and Neutral)...
      • Agent24
        I see dead caps
        • Oct 2007
        • 5095
        • New Zealand
        Re: Sck 054
        Yes, it's a thermistor, used for limiting inrush current in the PSU when the primary capacitors first charge up.
        SCK 054 is a common model I see in power supplies. You can buy them on eBay or electronics suppliers like Farnell, Digikey, Mouser etc.
        -David VanHorn
        • nmbb
          Can not find Model/Value of Thermistor.
          by nmbb
          Machine: Autoclave.
          Brand/Model: SANYO MLS-3780
          Manual: (Sorry search option not working on this PDF)
          Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
          06-02-2022, 05:55 PM
        • robm1
          Samsung TV LA46B650T1F Blown Fuse and Thermistor
          by robm1
          Picked up a non working LA46B650T1F. Opened the back up, and the fuse near the AC in (FS801S which looks to by a 6.3A slow blow ceramic) was blown.
          Further visual inspection showed the thermistor at NT811S (marked SCK 084) was cracked at the top. So i am assuming something else is shorted to cause the fuse to blow and the thermistor to crack? Am i on the right track?
          What else can i test - the power supply board is a bn44-00265a, and can't see any specific threads on this board, nor find the schematic. I see some similar samsung boards, there are suggestions to test components...
          03-07-2020, 01:00 AM
        • drscoot
          HP X360 convertible battery blown fuse error, not charging
          by drscoot
          HP Modelnumber: 14-dh0061nb​
          This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
          The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
          I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
          And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
          All these 3 batteries are charging...
          12-15-2023, 05:54 AM
        • w00pz
          Identify blown component on HP ENVY X360 13-arxxxxx, Motherboard G1 13 AMD X360 18740-1 448.0GA03.0011
          by w00pz
          I have blown a component on HP Envy x360 with motherboard G1 13 AMD X360 18740-1 448.0GA03.0011.
          Unfortunately there are no schematics available and the component was so blown the marking weren't readable.
          I have marked it with a red circle in the attached photos - sorry for the mediocre quality I was too much in a rush.
          Hope someone will be able to identify the component.
          Many thanks for your help!
          Edit: High-res picture added on a normal board (not mine)...
          11-08-2025, 02:48 PM
        • ohren
          What problems could this blown cap cause in a Marantz SR5400?
          by ohren
          I'm looking at a vented C513 in a Marantz SR5400 (photo included), in the FR section on page 24 in the service manual (https://audiocircuit.dk/downloads/ma...400-avr-sm.pdf).
          R533 right below it in the photo is charred, but measures the correct value.
          1. I'm not familiar with amplifier circuits (at all — don't know the difference between classes, etc.) so I was wondering what problems would manifest from a supposedly non-operational C513? I didn't hear anything odd when testing the output channel with a speaker. Is there a simple test that can be done...
          10-21-2025, 09:02 AM
