Capacitor check - Making sure I get it right
  • MaxAsh
    • May 2014
    • 35
    Hello - new to the forums. I've been doing a lot of reading/learning, and I believe I'm on the right track. Short version: My issue is a Sceptre X20WG-1080P monitor that powers on (LED light flashes) and I hear small click/pop sounds each time it flashes. Eventually the monitor will come on, sometimes after 5-10 mins. From all that I've read, clear capacitor issue. So I popped open the monitor, and sure enough I find 5 capacitors with rounded/bulging tops. My plan is to replace them all. I'm familiar with soldering, but haven't replaced LCD capacitors before. I want to make sure I purchase the correct ones. Here's the info I wrote down, as well as the part numbers I found over on Digikey. My concern is that some of my height measurements don't line up with what they have. Is it okay to purchase a shorter height, as long as the other stats on the capacitor match? Thanks in advance:
    (Qty 4) CapXon 1000uF 25V C735 KF 105ºC
    22mm (height) 10mm (dia)
    (Qty 2) CapXon 1000uF 16V C732 KF 105ºC
    I found part number P5544-ND (25V), not 100% sure what to select for the 16V. There's no 22mm, but I found several 20mm. The hours and ripple currents are diff though. Not sure. Assistance would be awesome, thanks!
  • mockingbird
    • Dec 2008
    • 5484
    Re: Capacitor check - Making sure I get it right
    You should really do a complete replacement, including the small capacitors on the logic board, and the large primary capacitor in the PSU (I have heard that CapXon primaries are somewhat unreliable as well).
    The part you chose is inadequate as a replacement because it is a general purpose capacitor.
    For 16V 1000uF:
    565-1664-ND
    For 25V 1000uF:
    1189-1245-ND
    • MaxAsh
      • May 2014
      • 35
      With so many going bad on this board, you're probably right about replacing additional caps. I'll look at the data on each one as well. I was confused about one portion of your reply: You said the ones I selected were inadequate because they were general purpose. I looked up the part numbers you suggested, and they also said general purpose under Applications on Digikey. Am I checking the wrong field in the description?
      Thanks!
      • mockingbird
        • Dec 2008
        • 5484
        While the big three have really improved their component descriptions (At least in the capacitor sections), they don't get everything right... Off the bat, when I saw NHG I knew it wasn't going to suffice because I'm a little familiar with the series.
        I linked you to KZE and ZLJ. I've used them before many times so I know those are both very low ESR and high ripple series. But you have to be smart about it when you shop at Digikey because sometimes one series is far better priced than another.
        The way to do it is to select the voltage, capacity, and maximum width in the parametric search and then filter it (Click "in stock" too). Once you have those results, choose "through hole" and then pick all the heights (in mm) up till your maximum height (A taller cap is not always better than its shorter counterpart - often, shorter caps have a superior electrolyte composition). Now filter it once more according to manufacturer. You want Nichicon, Rubycon, and Chemi-Con... Kemet and Vishay have started to get into the game a little more (And I sometimes buy Illinois Capacitor from Newark if the price is good), but you should stick to those three for the time being.
        Now sort it by price (Ascending - with the most inexpensive caps first), keeping in mind that you're only interested in products with a minimum quantity of one (Often you'll see obscenely inexpensive caps, only to realize that the nearby column lists them in minimum quantities of 1000). Now go down the list and find the most inexpensive capacitor that suits your needs.
        Since we're looking at those three brands, I'll tell you which series you'll most likely get in your results that are suitable:
        KZE, ZL, ZLG, ZLH, ZLJ, ZLK, HD, HC, HV
        These series might not be as low ESR and not have as high a ripple rating, but they are sometimes suitable, depending on the application:
        KY, YXJ, HE
        I'm sure there are some series I've missed out, but this is just to help you get started.
        And that's how you buy caps.
        • MaxAsh
          • May 2014
          • 35
          Awesome, absolutely awesome, explanation! Many thanks. It helped me find/purchase the additional caps I need to replace them all at once. At these prices, it would be a waste not to spend the mere pennies to get rid of these other junky CapXon caps.
          Huge thumbs up and thanks. I'll report back with the results of my efforts!
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Excellent writeup, mockingbird. That's how I usually sort capacitors in Digikey and Mouser as well. As an added step, I also choose only capacitors that have a 105C temperature rating. This removes the general purpose 85C caps.
            Speaking of general purpose...
            If I remember correctly, Digikey just labels all small leaded capacitors as general purpose. That's quite misleading, though, because as mockingbird pointed out, there are different series of capacitors, and some are better rated than others (hence, they are not all "general purpose") - i.e. lower ESR and higher ripple current. The term "general purpose" we use here on badcaps.net usually means "not suitable for power supply or motherboard use". One way you can actually distinguish general purpose caps from low-ESR caps is by opening the datasheet of the capacitor. If ESR/impedance is not listed anywhere in the datasheet, it's a general purpose capacitor. If it's a low-ESR capacitor, then your replacement capacitor should have preferably the same or lower ESR and the same or higher ripple current specs than the original capacitor you are replacing.
            • Prolog
              RTX 3080 FE Identifying capacitor
              by Prolog
              Hi people, I hope this is the correct spot to post this, I'm new to the forum.
              I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
              I hope these photos make it clear which component I am referring to:
              (yes, the soldering is a bit botched from removing the blown one, I know)
              I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
              12-01-2024, 08:27 PM
            • chth96
              If I replace with inferior capacitor, Is it No harm to other IC components at all?
              by chth96
              I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
              Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
              It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
              So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
              I know that these capacitor will not last as long as nichicon capacitor...
              12-22-2023, 04:34 AM
            • chth96
              How can I test non-polarized capacitor?
              by chth96
              I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
              I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
              And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
              I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
              06-02-2024, 07:31 PM
            • chth96
              Is it no harm to replace with capacitor without ripple current rating?
              by chth96
              When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
              Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
              But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
              Rubycon YK DataSheet (b...
              04-19-2024, 05:19 AM
            • chth96
              Should I replace polymer capacitor?
              by chth96
              a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
              I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
              Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
              Is this ESR value of polymer capacitor correct?...
              11-18-2022, 04:22 AM
