Hello - new to the forums. I've been doing a lot of reading/learning, and I believe I'm on the right track. Short version: My issue is a Sceptre X20WG-1080P monitor that powers on (LED light flashes) and I hear small click/pop sounds each time it flashes. Eventually the monitor will come on, sometimes after 5-10 mins. From all that I've read, clear capacitor issue. So I popped open the monitor, and sure enough I find 5 capacitors with rounded/bulging tops. My plan is to replace them all. I'm familiar with soldering, but haven't replaced LCD capacitors before. I want to make sure I purchase the correct ones. Here's the info I wrote down, as well as the part numbers I found over on Digikey. My concern is that some of my height measurements don't line up with what they have. Is it okay to purchase a shorter height, as long as the other stats on the capacitor match? Thanks in advance:
(Qty 4) CapXon 1000uF 25V C735 KF 105ºC
22mm (height) 10mm (dia)
(Qty 2) CapXon 1000uF 16V C732 KF 105ºC
I found part number P5544-ND (25V), not 100% sure what to select for the 16V. There's no 22mm, but I found several 20mm. The hours and ripple currents are diff though. Not sure. Assistance would be awesome, thanks!
